Code 14, 22 Help! Sputtering!
  • Thread starter Thread starter BullittAndy
  • Start date Start date Jan 8, 2006
BullittAndy
139
  • Jan 8, 2006
1991 LX 5.0 Car was running fine, no issues.
Then Checked codes, got 14 (ignition profile pickup) and 22 (BAR sensor)
-Replaced distributor (code 14)
-Replaced BAR sensor (code 22)
NOW it runs worse! Bad idle, sputtering inconsistently while driving. Smells like its rich. What happened? Any ideas?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 8, 2006
  • Jan 8, 2006
The MAP/BARO sensor you replaced is either defective or you have some bad wiring or connections for it.
Here's the checks for the wiring:
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter.
Check the resistance between the black/white wire on the MAP/BARO sensor and then the black/white wire on the EGR and the same wire on the TPS. It should be less than 1 ohm. Next check the resistance between the black/white wire and the negative battery post. It should be less than 1 ohm.
Next, turn the ignition switch to the Run postion, but don't try to start the car.
Vref (5 volt reference voltage supplied by the computer) missing or broken wire or bad connection in circuit. Use a DVM to check for 5 volts on the orange/white wire. If it is missing, look for +5 volts at the orange/white wire on the TPS or MAP sensor located on the firewall near the center of the car. Use the black/white wire for the ground for the DVM.
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
G
Persistent P0102 and limp mode
  • Godless
  • Oct 30, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Nov 11, 2025
Godless
G
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
