Code 21- Fixed????
  • Thread starter Thread starter fost9508
  • Start date Start date Nov 20, 2004
F
fost9508
131
  • Nov 20, 2004
Hey guys, I just removed the ECT (on the passanger side ) and reinstalled it checked the temp on the coolant, gauged at around 162 deg F. I measure the voltage out of the sensor and it measured at about .82 volts, which seems about right for that temp. Anyway, reinstalled it and now the code went away. This doesn't make any sense to me. Explaination please
Thanks in advance..
mozpony
17
liberty,N.Y.
Nov 20, 2004
  • Nov 20, 2004
You might have fixed just by removing and reinstalling the plug .Bad or dirty connection ?
HISSIN50
34
129
Nov 20, 2004
  • Nov 20, 2004
i still might check it some more - though i dont have a table in front of me to know if your value seems right (somehow it seems high, but i have nothing to base that on) - your sensor may not be tossing a code, but still might be out of calibration (within absolute specs but not correct for the given situation).
i think you did good - im just tossing out stuff for down the line if problems reoccur.
nice work.
F
fost9508
131
  • Nov 20, 2004
Hissin,
Here is the table I used....Posted by jrichker, I didn't interpolated the voltage but it is aleast between the two know temp/voltage values.....dunno????
Hissin....not to hassle you to much, but I posted earlier about Code 94 and 44 ....post title something like Code 44 and 94 Update....could you read through it to see if you have any ideas?
Thanks
Code 21 – ECT sensor out of range. Broken or damaged wiring, bad ECT sensor. Note that that if the outside air temp is below 50 degrees F that the test for the ECT can be in error.
The ACT & ECT have the same thermistor, so the table values are the same
ACT & ECT test data:
Use Pin 46 on the computer for ground for both ECT & ACT to get most accurate readings.
Pin 7 on the computer - ECT signal in. at 176 degrees F it should be .80 volts
Pin 25 on the computer - ACT signal in. at 50 degrees F it should be 3.5 volts. It is a good number if the ACT is mounted in the inlet airbox. If it is mounted in the lower intake manifold, the voltage readings will be lower because of the heat transfer.
Voltages may be measured across the ECT/ACT by probing the connector from the rear. Use care in doing it so that you don't damage the wiring or connector.
Here's the table :
68 degrees F = 3.02 v
86 degrees F = 2.62 v
104 degrees F = 2.16 v
122 degrees F = 1.72 v
140 degrees F = 1.35 v
158 degrees F = 1.04 v
176 degrees F = .80 v
194 degrees F = .61
HISSIN50
34
129
Nov 20, 2004
  • Nov 20, 2004
fost9508 said:
Hissin,
Thanks
Here's the table :
194 degrees F = .61
ok gotcha. sounds good (I knew i was not confident in knowing if that number was off, hence my saying so above. ). i think i recall a chart for ACT values (which as you know, are the same as ECT). however, the ACT chart did not go high enough in temps for your numbers (ambient temps seldom exceed 110*F - and if they do, you are in trouble. ).
i saw your other thread and Mario posted a really nice response - more eloquent than i could have put it.
Mustang5L5
Mod Dude
Feb 18, 2001
43,365
18,109
224
Massachusetts
Nov 20, 2004
  • Nov 20, 2004
An ECT sensor is $25 or so from a parts store. Why not just replace it and be done with it??
HISSIN50
34
129
Nov 20, 2004
  • Nov 20, 2004
Mike, stop with all this logical thinking - it takes away half the fun of the threads.
you are correct of course. we are like cats; we like to play with the stuff before we toss it and get new stuff.
Mustang5L5
Mod Dude
Feb 18, 2001
43,365
18,109
224
Massachusetts
Nov 20, 2004
  • Nov 20, 2004
Well my time is valuable these days. I just get right down to the point.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
R
93 LX 2.3 Trouble codes 53, 85, 21 help
  • Rickshaw302
  • Apr 15, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 18, 2025
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
