Code 31 help! PLEASE!
  • Thread starter Thread starter bigsparky
  • Start date Start date May 11, 2004
bigsparky
334
Saskatoon, Saskatchewan
May 11, 2004
  • May 11, 2004
My car runs absolutley fine. But at around 1500 rpm the check engine light comes on. It doesn't come on EVERY single time, but most of the time. It then shuts off usually around 2000 rpm. It doesn't matter if it's part throttle or full throttle, it still comes on. I pulled the codes and got a code 31.
I checked the EGR valve and it's fine. So I'm thinking it's the EGR valve position sensor. Would this make sense? I want to know before I go out and buy the new sensor. Is there any way to test the sensor? Any help is appreciated!
5.0guy
320
MI
May 11, 2004
  • May 11, 2004
do u have emissions testing?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 11, 2004
  • May 11, 2004
CODE: 31 (KOEO) - EVP circuit below minimum voltage. Vref (5 volt reference voltage supplied by the computer) missing or broken wire or bad connection in circuit. Use a DVM to check for 5 volts on the orange/white wire. If it is missing, look for +5 volts at the orange/white wire on the TPS or MAP sensor located on the firewall near the center of the car. With the sensor removed from the EGR and still connected, press the plunger and watch the voltage change on the brown/lt green wire. Check for the same results on pin 27 on the computer.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
