Code 34 Update
  • Thread starter Thread starter fost9508
  • Start date Start date Nov 20, 2004
F
fost9508
131
  • Nov 20, 2004
I keep getting code 34- EGR out of range..etc....
So I have done the following...
1) Applied vacuum to the valve with my vac pump. It opens and kills the car, expected. Good.
2) I go to the solenoid valve and don't get any readings from it when I probe the wires. I ground the circuit and the valve passes vacuum to the valve and the car dies.
I don't know what this means, but apprently the valve works, it just isn't getting the signal....at least this is what I think.
What is the next step???? Non of my books discuss what else to do
Thanks again
HISSIN50
34
129
Nov 20, 2004
  • Nov 20, 2004
one thing to check is that the EGR valve seat is not worn. basically the sensor will read incorrectly if the seat has worn. so it tosses a code.
good luck bud - sounds like you are picking them up and knocking them down.
86T-Top
553
Dublin, PA
Nov 20, 2004
  • Nov 20, 2004
Unhook the connector from the solenoid and hook a voltmeter to both wires. Rev the engine up and see if you get a reading. If there is no reading, then the ground is not being supplied. Do the same thing I told you to do in the other post about the other solenoids.
If you do get a reading, hook the connector back up, put a vacuum gauge on the solenoid and rev the motor to 2K. You should get a reading on the vacuum gauge. If you do than you got a problem with the egr sensor or egr valve.
Mario
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
J
Thanks for the information on codes 31,34,44 and 94!
  • JK86LX50
  • Mar 5, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 5, 2025
gkomo
