Code 41/91 help????
  • Thread starter Thread starter Strike One
  • Start date Start date Mar 2, 2004
Strike One
715
San Francisco, CA
Mar 2, 2004
  • Mar 2, 2004
The check engine light came on tonight when coming home and then went off after about 1 min. So I got home and checked for codes and I got 41/91 in the continuous memory. I looked up the code and it is "HEGO (HO2S) sensor signal out of range/always lean". Can someone explain what this sensor is? Does it mean I have bad O2 sensors?
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Mar 2, 2004
  • Mar 2, 2004
isnt it referring to the o2 sensors being too lean? maybe they are damaged. o2 sensors give a 0-1 volt signal reading which forms a wave pattern going 1volt then down to 0 in a matter of milliseconds. If for some reason it stays up at 1 volt for longer than normal the comp will ""think"" the car is running too rich and will decrease fuel which in turn will make your car run too lean. haha maybe im wrong about all this but that is my guess.
good luck,
Drew
Mavrick
2,264
Collingwood, ON
Mar 2, 2004
  • Mar 2, 2004
Ya those are o2's.. replace them, or try cleaning them if your strapped for cash.
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Mar 2, 2004
  • Mar 2, 2004
woo hoo i actually got it right!
Strike One
715
San Francisco, CA
Mar 3, 2004
  • Mar 3, 2004
Alright, thanks guys. I will switch them out soon and hopefully it works.
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
