  • 1994 - 1995 Specific Tech
code 543
  • Thread starter Thread starter blk945.0
  • Start date Start date Nov 11, 2004
blk945.0
  • Nov 11, 2004
I'm new to this board and to these cars. My daughter bought a 94 gt. The person she bought it from said it needed a fuel pump, which I installed. The car will run good and then will not start. After it sits for awhile it starts. I got this code, Code 543-fuel pump secondary circuit failure - battery to pcm. It doesn't miss or surge going down the road but when she shuts it off, sometimes it will not start. Am I correct thinking that the PCM is going bad? Thanks for any information.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Nov 11, 2004
  • Nov 11, 2004
Anytime you work on the fuel system you will get this code. Sometimes happens when changing the fuel pressure regulator or injectors. The EEC will detect power but a low fuel level so it will automatically shoot out a high circuit code or failure code. Sounds like the previous owner would run the tank bone dry often.
AznStanger3v
2,026
Northern VA
Nov 11, 2004
  • Nov 11, 2004
odd, ive changed my fuel pump, injectors, and regulator all to higher, aftermarket stuff and i have never had any of the fuel codes go on
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Nov 11, 2004
  • Nov 11, 2004
This code comes up a lot. Actually, I would do a search on this forum for "code 543". Someone did a write-up on it, using diagnostics CD that you can buy. It tells you step by step what to check and how to check it. It will narrow down your problem.
Obviously, the computer is detecting something is wrong. And since something is wrong, likely you are on the right track.
Do a search, and post back if you have any questions.
Scott
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
  • Gulftown980x
  • Jul 29, 2026
squeak93
