Code 67 and Code 84 Engine off test!
AnthonyR23
661
Ontario
Hi.. how does the computer sense that the EGR vacuum solenoid has a circuit failure... Would cleaning the egr valve possibly help this???
About the clutch switch circuit failure... I am able to start my car... so I don't think I have a big problem there.. When I did the test.. I ran the car for about 4 or 5 minutes.. shut it off... and did the test... was doing it my self so I wasn't sitting in the car when I did it... would that make a difference???
I am doing pretty good because I was getting a hole load of other errors before that I have gotten rid off.. Replaced a bunch of vacuum lines, etc..
I want to clear up the engine off codes before takling the engine on test error codes...
Any ideas of what else I can do?? Thanks Everyone!!!!!
Good news... code 67 is gone... I had the car in gear... that's why it came up... just getting code 84 now.. the connector was really corroted so I cleaned it up.. plugged the egr solonoid back in and am still getting code 84. I'm feeling good though cause I'm getting there.. my car isn't idling up and down anymore.. just sits at 1000 rpm which could still be a little high... but at least it is steady... any help on that 84 code would be great!!
Code 67 - clutch not depressed (5 speed) or car not in neutral or park (auto) or A/C in On position when codes where dumped. Possible neutral safety switch or wiring problem. This code may prevent you from running the Key On Engine On tests. You can generally ignore this code, since it has no effect on engine performance.
The computer wants to make sure the A/C is off due to the added load on the engine for the engine running tests. It also checks to see that the transmission is in Neutral and the clutch depressed (T5, T56, Tremec 3550 & TKO)). This prevents the car from being driven while the computer is in test mode. Key On Engine Running test mode takes the throttle control away from the driver for several tests. This could prove hazardous if the computer was jumpered into test mode and then driven.
Code 84 EGR Vacuum Regulator failure – Broken vacuum lines, no +12 volts, regulator coil open circuit. The EVR regulates vacuum to the EGR valve to maintain the correct amount of vacuum. The solenoid coil should measure 20-70 Ohms resistance. The regulator has a vacuum feed on the bottom which draws from the intake manifold. The other vacuum line is regulated vacuum going to the EGR valve. One side of the EVR electrical circuit is +12 volts anytime the ignition switch is in the run position. The other side of the electrical circuit is the ground path and is controlled by the computer. The computer switches the ground on and off to control the regulator solenoid.
Some basic theory to clarify how things work is in order…
The EGR shuts off at Wide Open Throttle (WOT), so it has minimal effect on performance. The addition of exhaust gas drops combustion temperature, increases gas mileage and reduces the tendency of the engine to ping. It can also reduce HC emissions by reducing fuel consumption. The primary result of EGR usage is a reduction in NOx emissions. A custom chip or Tweecer tune is the only way to disable the EGR in the computer’s programming.
The EGR system has a vacuum source (line from the intake manifold) that goes to the EVR, computer operated electronic vacuum regulator. The EVR is located on the back of the passenger side shock strut tower. The computer uses RPM, Load. and some other factors to tell the EVR to pass vacuum to open the EGR valve. The EGR valve and the passages in the heads and intake manifold route exhaust gas to the EGR spacer (throttle body spacer). The EGR sensor tells the computer how far the EGR valve is open. Then computer adjusts the signal sent to the EVR to hold, increase or decrease the vacuum. The computer adds spark advance to compensate for the recirculated gases and the slower rate they burn at.
There should be no vacuum at the EGR valve when at idle. If there is, the EVR (electronic vacuum regulator) mounted on the backside of the passenger side wheelwell is suspect. Check the vacuum line plumbing to make sure the previous owner didn’t cross the vacuum lines.
Diagram courtesy of Tmoss & Stang&2birds. (the diagram says 88 GT, but the EGR part is the same for 86-93 Mustangs)
The EGR sensor is basically a variable resistor, like the volume control on a radio. One end is 5 volt VREF power from the computer (red/orange wire). One end is computer signal ground (black/white), and the middle wire (brown/lt green) is the signal output from the EGR sensor. It is designed to always have some small voltage output from it anytime the ignition switch is the Run position. That way the computer knows the sensor & the wiring is OK. No voltage on computer pin 27 (brown/lt green wire) and the computer thinks the sensor is bad or the wire is broken and sets code 31. The voltage output can range from approximately .6-.85 volt.
EGR test procedure courtesy of cjones
to check the EGR valve:
bring the engine to normal temp.
connect a vacuum pump to the EGR Valve
apply 5in vacuum to the valve.
if engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
if engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
if engine stumbled, connect vacuum gauge to the hose coming off of the EGR Valve
snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
did the vacuum gauge show about 2-5 in vacuum?
if not, check for manifold vacuum at the EGR vacuum valve.
if you have manifold vacuum then connect vacuum gauge to the EGR valve side of the vacuum valve and snap throttle to 2500 RPM.
should read about 2-5 in vacuum
Late Model Restoration has the Ford Racing M-12071-N302 kit with the EGR valve & sensor along with the ACT & ECT sensors for $45. See http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=M12071N302 1&comp=LRS for more details
Thanks JRICKER! The code 67 is gone but thanks...
about the EVR.... I bought new vacuum lines and reran most of them so I doubt there is a vacuum problem...I got rid of some other vacuum error codes after installing the new vacuum lines... and the line from the top that goes directly to the egr valve isn't crossed with anything else.
I will check tomorrow to make sure there is no vacuum going to the egr at idle.. and at least 2-5 in vacuum when the throttle is reving at about 2500.
How much in vacuum should I be getting to the manifold line going into the EVR?
I will stick to this first and if everything seems ok with the EVR then I'll check the egr sensor.
I have a multimeter but I'm not sure how to check that the solenoid coil should measure 20-70 Ohms resistance.
