I have an '87 with a 5.0. So I started out with a code 34 and fixed all the egr things and the code went away but the car still idled rough. I pulled another code now #82. I researched and checked the voltage on the air diverter and on the red wire i got just over 12 volts and the white/red wire I got just over 1 volt. From what I read this is correct. The electrical connectors were dirty so I sprayed them off with cleaner and plugged them back in and started the car. Still got a rough idle and code 82. What my next step? replacing the diverter valve? Also is it normal for the car to blow smoke with this problem. I keep getting black smoke at start up and then white smoke.....the car has never blown smoke before the egr problems a week ago.
