code 91 and 13 help
  • Thread starter Thread starter mr.b
  • Start date Start date Dec 16, 2005
M
mr.b
214
  • Dec 16, 2005
ran a key on engine running test and got a code 91 (left bank o2 lean or not switching fast enough) and 13 (incorrect idle). I have been having a problem with the idle holding about 1200 rpm when it warms up. When the car is started for the first time (cold) it will idle perfect at 750rpms and then as it gets warmer and warmer it will slowly climb in idle speed to 1200. I unplugged the IAC valve and it doesn't make a difference in idle speed. It doesn't surge or anything, just idles high. COuld a bad o2 cause this, or IAC or what? Any help would be appreciated
did a cylinder balance test and it passed, also did a key on engine off test and it passed
car is completely stock 91 gt with 68,000 miles.
M
mr.b
214
  • Dec 16, 2005
any thoughts anybody?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 16, 2005
  • Dec 16, 2005
Code 41 or 91 - O2 indicates system lean. Look for a vacuum leak or failing O2 sensor.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter.
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
With an idle that climbs as the engine warms up, definitely look for a vacuum leak. The small hard plastic vacuum lines are very brittle and will crack easily.
M
mr.b
214
  • Dec 16, 2005
jr, which small hard plastic lines are u refering to?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 17, 2005
  • Dec 17, 2005
Unless you car has had them ripped out or replaced, there is one for almost every piece of smog equipment under the hood, the fuel pressure regulator and the HVAC controls.
See http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxFordVacuumDiagram.jpg for more information.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
C
Engine Code 13 and high idle
  • CmdrDerp
  • Dec 14, 2024
Fox 5.0 Mustang Tech Dec 21, 2024
manicmechanic007
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
