  • SN95 4.6L Mustang Tech
code p0153
  • Thread starter Thread starter OleYellarGT
  • Start date Start date Dec 2, 2005
O
OleYellarGT
64
Charlotte, NC
Dec 2, 2005
  • Dec 2, 2005
02 circuit slow bank2, sensor1.....does this mean that my 02 sensor is bad? If so is this the driver's side front sensor? Can I test the sensor by switching the front sensor from driver's side to passenger to see if code follows?
Thanks in advance
blackfang
1,290
Richmond, Va
Dec 2, 2005
  • Dec 2, 2005
Drivers side front air fuel sensor indicates the engine air fuel ratio is not being adjusted by the oxygen sensor signal or the ECM as expected to do so It could be the O2, the wires could be frayed to it, or that side has an exhaust leak.
RedBullitt
462
Morgantown WV
Dec 3, 2005
  • Dec 3, 2005
ok here you go, you swapped your x, did you snap off the clips that keep the o2 sensor wires from dangling? on my car not having the wires teathered and kept from moving the plug alot i got those codes. as soon as i wired them up tight i have not got either left or right side code again . i bet that is your problem.
babeabe19
77
SAC TOWN
Dec 3, 2005
  • Dec 3, 2005
ive had the same prob for months now. only my check eng doent come on even though i have the p0153 and p0133. nor have the codes come up for my rear o2 cuz i dont have ne cats. i know the bulb works cuz it comes on for a sec every time i start the car. i have no idea wat is goin on. i replaced my drv side o2 and the pass side code went away???????!!!!!!wtf? i dont see how not having the cables tethered would make a differance?
O
OleYellarGT
64
Charlotte, NC
Dec 3, 2005
  • Dec 3, 2005
guess I will be crawling under to make sure everything is tight....yes I did remove the clips holding the rear wires in place, have to to make the connections from the 02's to the MIL eliminators to the harness, but I used wire ties to tie the wires up and out to the way behind the transmission...... the front wires still retain the clips. thanks for the help....if anyone else has any ideas keep them coming.
RedBullitt
462
Morgantown WV
Dec 5, 2005
  • Dec 5, 2005
i do not know for sure why it would affect it. but i do know that when they were loose i got the codes, but when i wired them up i never got it again. somethings up there lol
O
OleYellarGT
64
Charlotte, NC
Dec 6, 2005
  • Dec 6, 2005
well here is an update....I cleared the code and so far it has not returned...the check engine light has not come back on. Still haven't had a chance to crawl under the car, but will do that this weekend.
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
squeak93
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
squeak93
