A few weeks ago I was getting a check engine light that would come on after I drove the car a few times a day. I took it to the shop and they said the only code they got was a bad egr code. I went to auto zone and got a new egr and put it on that afternoon. Check engine light was gone for about 3 days, then it came back on
I said what the heck and went auto zone again today to see if they had a code reader. They had an EEC IV reader for 30 bucks so I grabbed it. Hooked it up to the 5.0 and low and behold Im still getting a freaking EGR code, and 2 others. They are as follows according to my book...
Code 91 Exhaust Gas Oxygen (EGO) Sensor. signal voltage always indicates lean either during engin run test or normal engine operating conditions.
Code 33 EGR Valve Position (EVP) sensor or pressure feedback EGR (PFE) sensor indicates EGR valve is not opening. or EGR Valve Position sensor or pressure feedback EGR sensor indicates EGR valve not seated properly.
and finally Code 13 RPM out of specification during normal idle operation.
The code 13 I know whats causing it, the idle on my car has been set at ~900-1000 rpms ever since I first got it.
Im not sure what to make of the code 91, is that the same thing as a bad 02 sensor? If so, then I am almost certain I have lost at least 1 if not 2 cats which has probably contributed to the bad 02 sensor.
Im guessing for the Code 33 I just dont have the EGR valve seated properly on. Its a brand new valve, I doubt anything is wrong with it.
Any input you guys have would be greatly appreciated as always
