Coil over?
  • Thread starter Thread starter BlackPearl955.0
  • Start date Start date Jun 29, 2007
BlackPearl955.0
126
Blashyrkh, Wisconsin
Jun 29, 2007
  • Jun 29, 2007
I have a friend that is interested int my shocks and struts, they are not that old. But I was wondering what are the differences between coil over and strut and spring which I have been using? Are coilovers better for performance?
Therian
The Highlander
Waterloo, Ontario
Jun 29, 2007
  • Jun 29, 2007
define performance.
Generally they are, but it's totally dependent on spring rate.
Yobi1Kanobi
559
  • Jun 30, 2007
they are definately easier to tune for whatever you want...I installed my coilovers and i love the look a the ability to choose my ride hieght.. coulnt tell you how they ride yet though.
BlackPearl955.0
126
Jun 30, 2007
  • Jun 30, 2007
ok by "performance" I mean should I jsut sell the ones I have now which is Illumina struts and Pro Kit eibach springs. What would the differance be If I had coilover Illumina shocks with tokico springs. Roughly the same spring rate if not the same (didnt really look it up yet). Cause I currently have it set up like sock with springs outside and struts torward the center of the underside.
Yobi1Kanobi
559
  • Jun 30, 2007
well you dont have to get rid of your shock you would remove your current springs and replace it with a coilover kit that goes over you tokico shock... gratennelli makes one and so does griggs and maximum motorsport too. they would also be a good source of what spring rate to go with depending on what your goal with the car is...ie drag, road race, street...anyways you really cant compare the stock spring location even with after market spring to a coil over due to relocating the spring to the shock change the geometry front end. you can actually get a better handling car with a stock feeling ride. good luck in your quest.
BlackPearl955.0
126
Jul 1, 2007
  • Jul 1, 2007
Yea the thing is my car has x2 balljoints, bumpsteer, offset bushings, The thing is with the pro kit and the illumina I can adjust through the 5 levels. It doesnt adjust to drag or drift but I do not do that often. The dspec is what I was looking at for coil overs but I am afraid that is too much adjustibility for my needs.
Anyone have install pictures of coilovers? and what brands and types have you guys had good results with?
I know my set up works well enough for what i need, but I am sure I could do better
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
MRT hood struts shocks need replacement - where to get?
  • TTSaleen
  • Feb 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 10, 2026
Mustang5L5
Rack and pinion options
  • Bronco Bart
  • Sep 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
AeroCoupe
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
