Coil spring compressor???
  • Thread starter Thread starter backfocus
  • Start date Start date May 26, 2006
backfocus
254
Little Rock, AR
May 26, 2006
  • May 26, 2006
Does anyone know where I can get the right kind of spring compressor to remove my front springs. I rented one last night, it was an internal compressor with the hooks on it. The problem I had was that I couldn't get the hook end up through the spring. I had the spring extended as far as I could without it popping out.
Both the haynes and clinton manual I have show a compresser that has metal plates not hooks.
Any Ideas, what do you guys use? I have read about some people taking the control arm bolts loose, instead of using a compresser, but I would rather not do that.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 26, 2006
  • May 26, 2006
I bought the correct style from a tool company, it is VERY good Quality, but it cost over $200. IMHO it was worth every penny!!!
Skoobie
Damn...Tyler65's hot!
May 25, 2003
655
Vancouver, WA
May 26, 2006
  • May 26, 2006
Although the compressor is the correct way to do it...they are not necessary. Jack the car up. Let the spring decompress as far as the a-arm will allow. Then either pry it out with a bar or kick the a-arm down. With the spring decompressed that much there isnt really enough energy left in them to do any harm.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 27, 2006
  • May 27, 2006
The safest method by far is the use of the correct style spring compressor so that you do not need to make a special visit to the Dentist!
backfocus
254
Little Rock, AR
May 27, 2006
  • May 27, 2006
Shaker where did you buy your compressor?
Has anyone made one themselves?
N
niklid05
140
Kutztown PA 19530
May 28, 2006
  • May 28, 2006
you could make one yourself if you have a threaded rod. If your lazy like me you can get a set of compressors from sears for $40 bucks
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 28, 2006
  • May 28, 2006
I bought it last Spring, I am sorry I dont remember the name of the company. I just searched around Google until I found the best price. I am sure you can fab up something, but I would make sure the threaded rod is made of hardend steel. The Compressor I have weighs around 13 Lbs. it is VERY heavy duty and makes you feel comfortable using it knowing nothing is going to fly apart.
F
facemelter71
60
cincy
May 29, 2006
  • May 29, 2006
ill have to stick with just jacking the car up and letting the control arm sag, if the spring has been in there for some time itll be a little hard to get out but there is no energy left in it after arm is lowered as far as possible.just pry it out.i lowered my car in my drive way with hand tools a jack and a jackstand.
bubba-dough
1,044
Indiana
May 29, 2006
  • May 29, 2006
I made my own with threaded stock, steel plates, a couple of nuts and a welder. But then again we have everything to do anything at the plant. Getting the spring out is easy without the compressor. Its the getting them back in that you need the compressor for. Good luck.
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Gen 3 Coyote Swap Variable Displacement AC Compressor Troubleshooting
  • rydnoryder
  • Jun 12, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jun 16, 2025
rydnoryder
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
