Coil spring compressor
  • Thread starter Thread starter 65fastbackresto
  • Start date Start date May 15, 2007
First Prev 2 of 2
65intex
85
Ft. Worth, Texas
May 15, 2007
#21
  • May 15, 2007
  • #21
fasttback said:
Almost true, I think I had compress a little to get the springs in a 1966 and 1967. After cutting 1/2 to 3/4 coil, they slid right in after the method you mentioned.
Hey fasttback you got any pics of your car after you cut the coils that much?
65intex
85
Ft. Worth, Texas
May 21, 2007
#22
  • May 21, 2007
  • #22
The 620's did slide in after cutting about a 1/3 to 1/2 of the coil off but now the spring comes unseated when I jack the front end of the car up. Is there any way to keep the springs seated or will I just have to reset the springs every time the front end comes up?
CraigMBA
783
Orange, CA
May 21, 2007
#23
  • May 21, 2007
  • #23
Add a 1/2" spacer between the shock and the shock mount. Manditory with the Koni shocks to keep them from bottoming out.
Skymarshal
572
Dallas
May 21, 2007
#24
  • May 21, 2007
  • #24
Definitely use a chain as a backup! It's not unheard of for spring compressors to fail. Especially the cheap ones. Looping a chain through the spring and around a control arm is cheap insurance to keep the spring from coming out at you if anything slips or breaks.
Never cut or weld on a spring!
Springs are designed to work as a complete unit, and the ends are a different shape for a reason- it distributes the forces around the whole circumference of the spring seat.
And when you cut or weld a spring, the heat destroys the temper in that part of the spring, turning it from spring steel back into regular steel. Springs that have been subjected to high heat will crack and fail shortly after being put back in service.
D
DJCarbine
392
#25
  • May 21, 2007
  • #25
I rented the internal spring compressor from autozone, and used a bit of pipe as a hueg washer to get the amount of compression I needed. Perfectly safe if yout ake your time and pay attention to the spring as you compress it.
If you are prone to injury, I would suggest a football helmet, mouth guard, full body armor, and a pistol. You can never be too safe.
65fastbackresto
1,229
AR
May 21, 2007
#26
  • May 21, 2007
  • #26
I have been a little accident prone
In my life, but my buddy helping me is pretty good mechanic.
D
DJCarbine
392
#27
  • May 21, 2007
  • #27
You should be fine then. The hardest part for me was lining up the internal compressor so that it compressed the springs evenly, as one arm is longer than the other. Other than that, have fun turning the screw a million times to get the dang thing to compress
CraigMBA
783
Orange, CA
May 21, 2007
#28
  • May 21, 2007
  • #28
After you get the compressor centered, use an impact gun to compress it.
If the shaft isn't parallel with the spring, you have it misaligned. Sometimes the shaft will be dead center, sometimes it won't.
65fastbackresto
1,229
AR
May 21, 2007
#29
  • May 21, 2007
  • #29
DJ Carbine
What is a scarebird disk conversion?
D
DJCarbine
392
#30
  • May 21, 2007
  • #30
Scarebird front disc conversion bracket is sold on http://www.scarebird.com/
I am using the bracket with S10 calipers and 67 rotors, with a maverick dual cylinder MC. I have a writeup on them in the forums, do a search. 10k + miles on my daily driver 66, and they work great.
On a side note, I was told never to use an impact gun on the compressors as they have a chance of jarring the compressor out of the spring. I suppose that just being paranoid though
65fastbackresto
1,229
AR
May 21, 2007
#31
  • May 21, 2007
  • #31
Impact, never thought of that
glad you said that....I`d have prob tried it. I was gonna try and use a air ratchet on the spring compressor, dont know if it`ll work though.
I was told to put preload the suspension, put the compressor in, then let the tire hang, taking care of most of the spring compressing for me. That sound right to you?
D
DJCarbine
392
#32
  • May 21, 2007
  • #32
I did mine with the tire off the ground and removed already, I honestly don't see how you can do it with the tire on the car, drop the compressor in, jack the car up and finish it.....
It sounds like a good idea to save some time and sweat, but in the end I just did it the tried and true way. Its also easier to make sure the compressor is fully seated on there with the tire off and car jacked up.
I don't even know if its possible to do it the way you just said
Jester67
908
TN
May 21, 2007
#33
  • May 21, 2007
  • #33
yah just put a jack under the LCA and jack it up it will save you some work.
First Prev 2 of 2
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Stiffer front springs writeup from the old .net site
  • LILCBRA
  • Oct 24, 2022
1974 - 1978 Mustang II Talk & Tech Oct 29, 2022
Enzio
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
6K
Other Auto Tech Jul 28, 2024
manicmechanic007
J
Electrical No crank no dash no nothing, troubleshooting leads to more questions
  • Jojam99
  • Jun 2, 2022
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Jun 2, 2022
Jojam99
J
