coil springs
meweehaa
202
Northeast PA
:shrug: I have a 69 coupe with a 302. I have standard springs cut down 1 turn and te car still rides pretty high in the front. Are the 620# 1" drop ok as a replacement to get it down? Should I replace them with the 620s? :bang:
NorCal66 said:
I agree 620s would probably be equivalent to what you have now, try cutting coils off the 620s, that should do the trick. :D
When cutting 620's to lower the car you need to measure the coil and remove approximately 1.25 inches from the center section. :D
Find a coil spring shop near you. I used one in Concord CA. (Coil Springs Inc.) and they made the springs for my kitty then after all was installed I took the car back to them and they adjusted the level. Less than $150 :nice: One inch drop and stays level in the corners. Ride is not too bad.
meweehaa said:
the ones i have aren't old just stock and cut down 1 coil. the thing is the car still sits high.
i put some 1" lowering springs on mine, and it did the trick (not in the vid)
might be a hair too low actually (or i could probably get slightly smaller tires)
of course we have different year cars - so thats something to consider too
old height
new springs
*and lets leave hoopty out of the conversation of my pics this time guys, thanks
