Laser said:I just got an 02 Mustang GT, and I want to add a cold air intake, but not sure which I should go with. Any suggestions?
Laser said:Is there a reason why you said JLT instead of another brand? Is JLT better than the others?
mustangkid05 said:jlt is highly reccomended......one of the best imo
Someone said once that the CAIs benefit the NPI engine more than the PI, I kind of wonder if that is true.stangGT97 said:Someone said once that the CAIs benefit the NPI engine more than the PI, I kind of wonder if that is true.
Both engines have the same stock intake tube, but the rest of the intake system: manifold, heads, cams, is much less restrictive in the pi motor, therefore, the pi motor should see more gain as you are replacing a part that is relatively more restricting to the pi motor vs the npi motor.
