  • SN95 4.6L Mustang Tech
Cold Air Intakes, what other things are needed after install if anything?
  • Thread starter Thread starter Seraphitia102
  • Start date Start date Jun 16, 2005
First Prev 2 of 2
Seraphitia102
will post boobie pics for a supercharger
Oct 11, 2004
737
California
Jun 17, 2005
#21
  • Jun 17, 2005
  • #21
Give Me TP said:
It may make you run on the lean side if you upgraded your catback. Get a dyno run in before and after installing the FIPK if you can.
Wow are you serious that the FIPK can throw off my air-to-fuel ratio with my custom catback?
Give Me TP
936
Republic of Texas
Jun 17, 2005
#22
  • Jun 17, 2005
  • #22
It will make it leaner, how much you won't know without wideband 02 monitoring. It may not be enough to be a concern, but in my case it was.
CaliLifeStyle
625
Oxnard, CA
Jun 17, 2005
#23
  • Jun 17, 2005
  • #23
If you do run lean you have the Diablo Predator to help you out.
Give Me TP
936
Republic of Texas
Jun 17, 2005
#24
  • Jun 17, 2005
  • #24
Cured completely with a custom Diablo tune
Seraphitia102
Oct 11, 2004
737
California
Jun 17, 2005
#25
  • Jun 17, 2005
  • #25
Do you mean I can adjust the parameters myself with the predator or do you mean a custom tune + predator to help me out?
Give Me TP
936
Republic of Texas
Jun 17, 2005
#26
  • Jun 17, 2005
  • #26
You can adjust them yourself, but you need a wideband 02 gauge/datalogger to do so. Dyno shops have them, or you can install one in your car as I did. They are relatively expensive compared to most other types of gauges.
You cannot adjust parameters on the Predator tuner itself to the degree that a custom tuner can with Diablo CMR software. For instance, say I had a lean spike in A/F ratio between 3500 and 4000 rpm. The Predator as it's delivered will only allow adjustments in two ranges, 2000-4000 and 4000-7000 rpm. If I richened up the ratio in the entire 2000-4000 range, I would now probably run rich between 2000 and 3500 rpm. A custom tuner with the CMR software on the other hand can adjust for much smaller rpm ranges, and target only the range that needs adjusting.
Seraphitia102
Oct 11, 2004
737
California
Jun 17, 2005
#27
  • Jun 17, 2005
  • #27
thank you for your input i'll remember the main points to take care of when if i get a cold air intake
First Prev 2 of 2
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2026
Ryu
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
M
Inheriting (and likely restoration of) a 1965 Mustang
  • miniwheats235
  • Feb 17, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 19, 2026
Realmongo
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
