cold air=sluggish??
  • Thread starter Thread starter 89GtConvert5spd
  • Start date Start date Apr 22, 2006
89GtConvert5spd
58
  • Apr 22, 2006
just spent a crap load for a bbk cold air intake, just got done installing it, now it idles rough, and is sort of sluggish in lower rpm range, kinda makes a thup thup thup thup noise...and the check engine light turns on for a few seconds and shuts off, im assuming im running too lean...any solutions/suggestions?? its a stock 89 gt with a aftermarket mass-air..
mjmatt1978
9
  • Apr 22, 2006
check your plug wires, maybe you knocked something loose
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 22, 2006
  • Apr 22, 2006
did you wreck something on your MAF or did you forger to flug it back in
89GtConvert5spd
58
  • Apr 22, 2006
*runing ouside to check*
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 22, 2006
  • Apr 22, 2006
LOL that has been known to happen it's always the stupid stuff you overlook.
89GtConvert5spd
58
  • Apr 22, 2006
all plugs are tight, how can i tell if maf is damaged?
89GtConvert5spd
58
  • Apr 22, 2006
the maf got bumped a tiny bit but not enoguht to break anything, any other ideas?
89GtConvert5spd
58
  • Apr 22, 2006
been reading somethin about clocking, will this make an immediate difference or will i have to drive around to notice?
89GtConvert5spd
58
  • Apr 22, 2006
well turned the mass air every direction but upside down, still does it, tried buttin the stock maf on, still does it....please...anyone??? anything??
vristang
4,933
101
124
Seattle
Apr 22, 2006
#10
  • Apr 22, 2006
  • #10
Does your kit bend immediately before the MAF?
A tight bend just before the MAF will do bad things to the signal.
Check out Fig. 7 here... http://www.ceesi.com/pubs/117_Flowmeter_Installation_Effects.pdf
Clocking seems to work for many, but I can't say it solves everyones problems.
Good Luck
jason
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 22, 2006
#11
  • Apr 22, 2006
  • #11
See previous post...see ebay to sell the unit you have and buy a nice K&N panel filter for you stock box.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 22, 2006
#12
  • Apr 22, 2006
  • #12
stock box with K&N is as good as any
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Apr 22, 2006
#13
  • Apr 22, 2006
  • #13
If you want to retain the "bling" of the cold air kit...you should look at the Mac straight shot system...though it does use the same under hood element style, the filter has a stainless shield over it to prevent "fan wash" issues as I had mention as a possible cause for your problems. A great looking pc though a bit more than your average BBK system. By the way the identical mac standard CAI systems...though likely would give the same problems, are only 79 dollars if you click on the "parts" icon at the top of the stangnet banner and check out the site.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
