Cold Leak Down Numbers
CarMichael Angelo
8,909
234
Birmingham, al
Performed a leak down test on the monster to take his pulse so to speak. Everything I try to read gives just as much conflict as confirmation.
I leaked the engine stone cold...It hasn't ran in weeks.
#1 = 10%
#2 = 11%
#3 = 19%
#4 = 14%
#5 = 21%
#6 = 12%
The three in the middle absolutely are the worst,...but here is the point of contention...some things you read claim that hot numbers could go as high as 5% better than cold numbers, while others claim that there is little to no difference between the two.
(which I find really hard to believe)
If I actually pick up 5% then even at 19 cold, I believe that 14% hot isn't that bad...every other cylinder would be more than acceptable if that would be the case..
It's blowing by the rings I know that,...the oil filler cap is off, and I have a piece of tissue paper hanging over the hole..Every time I pressurize a new cylinder, that paper starts flapping in the breeze...
Who knows if there is a definitive answer here?
Reactions: RaggedGT
I would do a compression test and compare. If the compression test numbers are down on the cylinders with the high leak down, then it is a confirmation of that cylinder being a problem. Leak down tests can be tricky to do right. Getting the cylinder at true TDC is key. I never rely on just a leak-down test, I always back it up with a compression test. Always perform the compression test with a battery charger hooked up so the cranking rpm stays the same for all cylinders.
Reactions: a91what
Had trouble with a lot of oil in intake on my Spec Miata, excessive blow by, would start smoking by end of track day. At first it was due to oil in intake, after three track days had gotten much worse. Did compression test, all were within 10% of what it should be, did leak down, # 1 was worst at 25%, air screaming out vent tube. Did not matter hot or cold, smoked constantly at this point.
Got a spare block with the car, unknown history. Took pistons out, found rings all gunked up and stuck in grooves, guessing this is problem with existing engine but have not torn it down yet. Getting other short block rebuilt over winter, won't get chance to see until I change it out.
