Performed a leak down test on the monster to take his pulse so to speak. Everything I try to read gives just as much conflict as confirmation.
I leaked the engine stone cold...It hasn't ran in weeks.
#1 = 10%
#2 = 11%
#3 = 19%
#4 = 14%
#5 = 21%
#6 = 12%
The three in the middle absolutely are the worst,...but here is the point of contention...some things you read claim that hot numbers could go as high as 5% better than cold numbers, while others claim that there is little to no difference between the two.
(which I find really hard to believe)
If I actually pick up 5% then even at 19 cold, I believe that 14% hot isn't that bad...every other cylinder would be more than acceptable if that would be the case..
It's blowing by the rings I know that,...the oil filler cap is off, and I have a piece of tissue paper hanging over the hole..Every time I pressurize a new cylinder, that paper starts flapping in the breeze...
Who knows if there is a definitive answer here?
#1 = 10%
#2 = 11%
#3 = 19%
#4 = 14%
#5 = 21%
#6 = 12%
