cold relay help
Doc90
38
texas
hey guys i need some advice my fuel pump relay does not cut off after priming when it is cold out side it will just run and run you can get it to start but you have to keep giving it gas after it has been run like that for a few minutes then you can get it to prime and stop run just fine i have replaced the relay about three times and ive had the car about a month and a half. could it be the fuel pump or the wiring to the relay? sometimes the relay sounds lke it is buzzing too?
WHen it does this, put a meter on the FP relay ground (tan/lt grn IIRC. CHeck the schematic for your model year) and see if it is remaining grounded after the time-out. If it isnt but the relay stays energized, the relay is possibly bad.
Good luck.
