Cold start still sucks!
  • Thread starter Thread starter LaserSVT
  • Start date Start date Jun 30, 2007
LaserSVT
3,548
233
Jun 30, 2007
  • Jun 30, 2007
I am still having problems with my cold starting. I have to give it gas or it will die and it will make a couple muted "pops" like little backfires I can hear through the intake. No codes, 700 rpm base with IAC and distributer plug removed, new IAC, new ACT, ECT is fine, 14 deg base timing, cleaned mass air and t-b. The IAC is from Autozone and did not say to mount upside down. It will also "hunt" idle rpm until its warm (after 2-3 min) What am I missing?
corvetteguy
71
  • Jul 1, 2007
Sounds exactly like my MAF being dirty on
my 89
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 1, 2007
  • Jul 1, 2007
If you read the "Surging Idle Checklist carefully you will find that a cone filter under the hood is a big no-no. The disturbed airflow through the MAF causes all sorts of problems. Sometimes clocking the MAF helps.
See "Surging Idle Checklist for help with all your idle problems. The first two posts contain all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
G
greg251
55
  • Jul 1, 2007
I second the vote on MAF. Mine did the same thing, put factory MAF back on problem solved.
LaserSVT
3,548
233
Jul 1, 2007
  • Jul 1, 2007
Thanks, read that sticky till I was cross-eyed, I was under the disillusion that sensor was ignored during cold start. When my hood shows up in a couple days I will be using the through the hood intake and see if that solves the problem, if not I guess I will locate a stock mas air and go from there. Will keep posted.
LaserSVT
3,548
233
Jul 1, 2007
  • Jul 1, 2007
I just flipped my IAC upside down and she fired right up and idled well with no stalling, my high idle time is a little too short so I guess I would have to reprogram my ECU for that, but the problem is I cant leave the IAC upside down because the plug hits the hood. How does everone else flip the thing and get it to clear the hood?
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
