well this is sort of a continuation of my previous thread about blow by issues
i ended up cleaning up my plugs but still a misfire...so i figured maybe theres gunk built up in the cyl so i decided to step on it for the first time after the misfire issues started in order to blow the dirt out
to my surprise i hear a loud knocking...right away i pulled over to see where it is from...i used a stethoscope and listen to the valve cover...a knock over cyls 3 & 4 (not sure which one exactly tho)
when i rev it, it sounds just like a motor with no oil - except of course its not as bad or as loud but enough for you to clearly hear it even over the loud exhaust
my thinkin is this is whats causing the misfire
am i wrong?
and now i gotta look into roller rockers (ill replace them as well even if the lifters are the issue)
Now i have two questions
(1) will 1.7 RR's n a TFS stage 1 cause piston to valve issues?
(2) do i need to lift the head out to remove the lifters or can i just use a magnet to lift'em out of the head?
SORRY FOR THE LONG POST !!! (id rather give more info than leave some things out)
THANK YOU & HAPPY THANKSGIVING EVERYONE !!!
am i wrong?
ill get some light 1.6's
Now it's out of my head. 99% of the time i am wrong! Thank you for listening.
