  • 1994 - 1995 Specific Tech
Combo?
  • Thread starter Thread starter sl03gt
  • Start date Start date Feb 28, 2007
sl03gt
20+ Year Stangneter
Sep 29, 2003
182
Feb 28, 2007
  • Feb 28, 2007
Thumper heads and a typhoon intake with stock cam? Searched and couldn't find exactly what I was looking for. Thanks for your replies.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 28, 2007
  • Feb 28, 2007
What info are you looking for exactly? Sounds like a pretty decent budget-minded combo, but I'd throw a cam in if I was already in there.
sl03gt
20+ Year Stangneter
Sep 29, 2003
182
Feb 28, 2007
  • Feb 28, 2007
Just don't want to put to much intake on and kill the performance.
PF intake 1500-6500 rpm
heads idle-5500?
Just curious if anybody is running a similar combo with stock cam.
BlownFiveLiter
18
108
Chicagoland
Mar 1, 2007
  • Mar 1, 2007
It's true you may lose a little low end from the PP intake and something like a GT40 based intake would be better suited to the stock cam, but usually those get a little more pricey than the Typhoon unless you're running an Explorer intake. Why no plans for a cam swap? You can usually pick up a B or E cam (I know, Ford alphabet cams are outdated) for cheap, especially a used one. You could even do it on the cheap and reuse your stock lifters if you're in a bind since it's not as critical to use new ones with a roller cam, versus a flat tappet.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Fox Goonies car
  • keel
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
keel
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Clearance
  • 1993mustang50
  • Apr 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2026
2000xp8
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
