  • SN95 4.6L Mustang Tech
comp cam XE274H
  • Thread starter Thread starter 96SCstang
  • Start date Start date Jul 28, 2009
96SCstang
228
novi, MI
Jul 28, 2009
  • Jul 28, 2009
will this cam be too big? i dont want to have to flycut the pistons. i have npi heads so i was told i shouldnt have to degree or anything but i want to ask you guys first. oh, and is this cam decent for a blower setup? i have a lead to get a set of these for cheap but i need to know that they will work on my car without any major problems and be worth the time. i already know i have to do springs, so that is not an issue really. thanks guys.
bboylobo
130
Lancaster PA
Jul 28, 2009
  • Jul 28, 2009
well the stock PI cam has a lift of .505/.531
I think this would work since its only got a lift of .487" / .490"
but Ill let a real professional answer you question though.
Blackone51
201
  • Jul 28, 2009
Am I just mistaken or is degreeing a cam just verifing that Comp cams gave you the right cam?
J
jomull55
202
lucas, OH
Jul 28, 2009
  • Jul 28, 2009
you are mistaken.
Mustang Forum - Mustang World - 4.6L SOHC/DOHC Camshaft Degree Procedure
Blackone51
201
  • Jul 28, 2009
jomull55 said:
you are mistaken.
So how do you like your hi-techs, I am thinking about getting the stage 2 blower cams? I will certainly use that thread when I get them.
nyuk98gt
1,427
Chesterfield, MO
Jul 28, 2009
  • Jul 28, 2009
96SCstang:
Call the Comp Tech Line and ask the lads if the cams are blower friendly. Call HiTech, too, because they are good guys. I will opine that 274's have too much overlap (intake and exhaust open at the same time) for a supercharger. Yes, you need to degree aftermarket cams. The stock cam gears are sloppy and can result in pretty gross mistiming (e.g.-- "minus 6 on one side and plus 7 on the other" is entirely possible). Sometimes the gears line up perfectly and the result is a "factory freak" that outrun cars that are the same otherwise.
A few phone calls will pay dividends.
HTH,
Chris
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
Engine Heads and how to buy
  • Dontknowchit
  • Aug 16, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
