As many people suggested, I e-mailed comp asking them what cam they suggested and he suggested a cam I have never heard of before:
I think I'll stick with the XE262H, what do you think?
I would run this part #31-412-4, this is one of my specialty cams. It
is kind of a small cam with a tight seperation, which will provide torque and
the sound you are looking for. Here is the spec card for that cam.
Cam Spec Card Inquiry
PART NO. 31-412-4
01 INTAKE MASTER 260H-9
02 EXHAUST MASTER 268H-9
03 ENGINE FS 260AH-8
04 GRIND NUMBER FS 260AH-8
INT EXH
05 HYDRAULIC Y/N YES 14 DUR @.050 212 218
INTAKE EXHAUST 15 LOBE LIFT .2960 .2960
06 VALVE ADJUSTMENT HYD HYD 16 ROCKER RATIO .00 .00
07 MAX GROSS VALVE LIFT .474 .474
08 DUR @ .006 TAPPET LIFT 260 268 17 LOBE SEPARATI 108.0
18 ADVANCE 0
09 VALVE TIMING OPEN CLOSE 19 VALVE SPRINGS
@ .006 10 INT 22 58
11 EXH 62 26 DATE SETUP / /
12 THESE SPECS ARE FOR CAM(S) INSTALLED
@ 108.0 INTAKE CENTERLINE
