complete dss 306
  • Thread starter Thread starter Adams91LX
  • Start date Start date Aug 23, 2006
Adams91LX
689
12
29
Plano, TX
Aug 23, 2006
  • Aug 23, 2006
so the supercharger ready 306 efi.... complete engine from dss...
what kind of hp might you expect?
SPECS:
Shortblock: Pro Bullet 306 w/ MSS
Heads: Trick Flow Twisted Wedge Highlift
Camshaft: Anderson B41
Rockers: DSS Aluminum Roller Rockers
Oil pan: DSS 7qt w/ power adder oil return
Oil pump: DSS high volume w/ adjustable bypass
Windage tray: DSS aluminum Pro-Tray
Balancer: Romac SFI approved steel
Flywheel: Fidanza SFI billet steel
Water Pump: DSS/Engine Works high flow
Distributor: MSD Pro Billet
Intake: Trick Flow Track Heat
Valve Covers: DSS short valve covers
thanks!
-a
stang22
1,318
Washington, D.C.
Aug 23, 2006
  • Aug 23, 2006
You said it is supercharger ready, but are you going to put a supercharger on it now?
Adams91LX
689
12
29
Plano, TX
Aug 23, 2006
  • Aug 23, 2006
not yet...
-a
Kabuki_notch
670
394
113
Rochester, NY
Aug 23, 2006
  • Aug 23, 2006
I am sorta curious as well, I am going for the same setup except AFR's and 10lbs of boost
89white50
440
central MA
Aug 23, 2006
  • Aug 23, 2006
without boost i say you are at 295-300 rwhp. 340ish tq. with 8-10 lbs youll be flying at 430+ rwhp. my guesstimate...
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Aug 23, 2006
  • Aug 23, 2006
Isn't the DSS block a stock block?
Adams91LX
689
12
29
Plano, TX
Aug 23, 2006
  • Aug 23, 2006
dunno... i was just wanting to know how much better this crate setup is over the ford racing 5.0 crate is... fordracing says 345hp... and its like half the cost... so what's the deal?
-a
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Aug 23, 2006
  • Aug 23, 2006
cast pistons, and rods, and I believe it has a cast crank. But the problem is if you arent going to go with a dart block or something of the like, both of those engines will die around 500hp, and crack the block.
Josh
Adams91LX
689
12
29
Plano, TX
Aug 23, 2006
  • Aug 23, 2006
yeah... well im not looking for anything over 400... my goal is just like 350-375... dd
-a
gcwh02
515
pottstown, PA
Aug 23, 2006
#10
  • Aug 23, 2006
  • #10
if you dont get 350 with a blower than somethings wrong
Adams91LX
689
12
29
Plano, TX
Aug 24, 2006
#11
  • Aug 24, 2006
  • #11
im looking for 350 n/a...
-a
cdog301
236
richmond ,ca
Aug 26, 2006
#12
  • Aug 26, 2006
  • #12
Those are not cast pistons and rods in that motor do your homework the pro bullet has all the upgrades all good balanced parts! The ford crate is the cheap S...!
Adams91LX
689
12
29
Plano, TX
Aug 26, 2006
#13
  • Aug 26, 2006
  • #13
okay... im newb... deal..
thanks for the input everyone..
-a
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Aug 26, 2006
#14
  • Aug 26, 2006
  • #14
im talkin about the ford crate engine.
Adams91LX
689
12
29
Plano, TX
Aug 26, 2006
#15
  • Aug 26, 2006
  • #15
alright cool cool... so for me, wanting 300-350hp n/a... worth the extra 3k to go with the dss over the ford crate?
-a
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Aug 26, 2006
#16
  • Aug 26, 2006
  • #16
yes.
W
WhiteHeat306
283
Philadelphia Suburbs
Aug 26, 2006
#17
  • Aug 26, 2006
  • #17
That Ford crate motor will not give 350 rwhp. That number is based on flywheel horsepower. With the setup you listed you should be making between 310-320rwhp.
Adams91LX
689
12
29
Plano, TX
Aug 26, 2006
#18
  • Aug 26, 2006
  • #18
cool cool... dss it is..
-a
50gt1988
154
Spanaway, WA
Aug 26, 2006
#19
  • Aug 26, 2006
  • #19
go with dss I bought my short block from them and couldn't be happier.
sketman
1,379
12
58
Palm Bay, FL
Aug 26, 2006
#20
  • Aug 26, 2006
  • #20
What he said.
And I'm happy with my DSS motor.
DSS Racing 347 CID Stroker Super Pro Bullet Long Block assembly * :
  • 185 61cc cylinder heads with upgrade to .600" lift springs *
  • ARP Hex Head bolts *
  • 1.6 ratio aluminum rockers *
  • Pro Gear 3 position double-roller timing chain *
  • Ford Racing hydraulic roller lifters *
  • 4130 .080" wall seamless pushrods *
  • Fel Pro graphite 8548 gaskets *
  • Level 10 CNC block with O-ringed deck *
  • forged 5.400" full floating 4340 H-beam rods *
  • forged Pro-Lite pistons *
  • billet aluminum main support system *
  • XE274HR camshaft (.555 intake, .565 exhaust) *
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
