- Mar 30, 2005
- 4,749
- 95
- 134
Do I have to open the bleeders to do this or is it safe to force fluid backwards through the lines?
Kilgore Trout said:Here is what the Bullitt Archive has to say...
NOTE: Just to be safe when compressing the pistons back into the caliper, instead of forcing the fluid backwards through the ABS unit and the Master Cylinder, first install a hose on the bleed screw, so it can drain into a jar and then loosen the bleeder. This way you are just pushing the fluid out instead of backwards through the system. Don't forget to tight the bleeder screw after the pistons have been seated.
Forcing the fluid back through the ABS unit can damage some types of systems. I was not able to verify that ours would be damaged but why take the chance.
same heresvttech76 said:every brake job I have done I did with either a big pair of channel locks to compress the caliper or with the correct tool for the twist in kind.
Kilgore Trout said:Well, what I was unsure of is whether forcing fluid back through the ABS module would damage the ABS module. Now I know the answer![]()
i didnt find this thread soon enough to add to it, but i would have just quoted what SVTTECH said anyway. logically thinking, theres no way air can get into the system by compressing the piston at the caliper.svttech76 said:every brake job I have done I did with either a big pair of channel locks to compress the caliper ( if it's dual piston like a mustang then you leave the old pad in and use the channel lock in the middle of the old pad) or with the correct tool for the twist in kind.
I have never have had to open the bleeders, if you need to open the bleeders to get them to compress then you need new calipers.
so NO you do not have to open the bleeders while compressing the caliper and NO you don't have to bleed them after your done.
DerekStangGT said:i didnt find this thread soon enough to add to it, but i would have just quoted what SVTTECH said anyway. logically thinking, theres no way air can get into the system by compressing the piston at the caliper.
lol, good one. our shop still has a "patch job" in the wall from some stupid "tech" who neglected that last stepsvttech76 said:ohh one last thing. remember to pump the brakes before you start up and drive away
The question was whether the ABS unit would be damaged by fluid being forced through it in the wrong direction. It had absolutely nothing to do with air in the lines.DerekStangGT said:i didnt find this thread soon enough to add to it, but i would have just quoted what SVTTECH said anyway. logically thinking, theres no way air can get into the system by compressing the piston at the caliper.
no tool needed...
