Compression check, what normal?
  • Thread starter Thread starter Skoobie
  • Start date Start date Jun 24, 2005
Skoobie
Damn...Tyler65's hot!
May 25, 2003
655
Vancouver, WA
Jun 24, 2005
  • Jun 24, 2005
Finally broke down and had the local shop do a compression check on my 188K shortblock just to guage how much time I had left on the motor. All cylindars checked in at 160-165 psi. I asked him what that ment and he said it wasent really important what the #'s were, but more so that they all read the same. It showed that all my valves were ok. He also said that there is no set "good" psi as it can vary widely depending on your cam choice. I currently have an E cam in with 1.6 RR. How does my compression compare to a new motor? Am I still in the black, or should I start saving for a rebuild?
1EVIL88VERT
314
Dyess AFB, TX
Jun 24, 2005
  • Jun 24, 2005
those are good numbers, as long as they are all within 10%. My 3000 mile shortblock only has 155psi.
D
Daggar
3,902
  • Jun 24, 2005
The shop manual shows a 25% difference to be acceptable. If you're within 10 then you're golden!
D
double drop top
10
Chandler Arizona
Jun 24, 2005
  • Jun 24, 2005
The second test you need to do is a leak down test. This will give you a better read on the condition of your rings and valves then a compression test.
Skoobie
May 25, 2003
655
Vancouver, WA
Jun 24, 2005
  • Jun 24, 2005
The leakdown was an hours labor by itself...that can wait
HISSIN50
34
129
Jun 24, 2005
  • Jun 24, 2005
Or just buy yourself a compression gauge (20-40 bucks at parts stores) and do it yourself.
I would have done a wet compression test afterwards, but I would not have paid someone to do the test, esp after the numbers you put up (very very good, IMHO).
Good luck.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jun 24, 2005
  • Jun 24, 2005
The compression test, like said before, the numbers really don't matter unless they are really low becuase you need at least 70psi for combustion. It's evenness that your are looking for.
Actually, this is the really important test to check engine performance condition.
My old motor, read between 155-165 across all cylinders. Great right?
Wrong, when I did a leakdown test I was getting 26% leakdown on #3 but all the rest werein the hight 30's low 40's, and #6 was at 50%.
10% or less = Excellent
Under 20% = Good
Under 30% = Acceptable
31% or more you have problems.
Skoobie
May 25, 2003
655
Vancouver, WA
Jun 25, 2005
  • Jun 25, 2005
What kind of equipment do you need for the test? Cost Vs. having a shop do the test?
Vipersix
434
Clarksville, TN
Jun 25, 2005
  • Jun 25, 2005
You might be able to rent one from Advance or Auto Zone, otherwise you can buy one from Summit for $70.
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
