We've run 9.5:1 on pump gas with over 12psi on boost however we are using a tuner, PMS, etc...to keep track on the timing and fuel. It also denpends how efficent the chamber in the heads are, etc..
Probe makes a nice 4cc flat top
With a 61cc chamber STOCK for a TFS you get 9.2:1 with a o deck, if the pistons are in the hole .010" it is 9.0:1. With a 58cc head (NOT KNOWING EXACTLY HOW FAR YOUR WERE MILLED) it will raise it .34 to 9.54:1 at a o deck.
Even if the heads have been milled down to 58cc chamber you would only be 9.5:1. You do realize that you will need to have the rotating assembly balanced with the new pistons, rings, etc...
