  • SN95 4.6L Mustang Tech
Compression Ratio, help me understand?
  • Thread starter Thread starter Screamin' Demon
  • Start date Start date Dec 11, 2004
Screamin' Demon
204
winchester, va
Dec 11, 2004
  • Dec 11, 2004
Alright as we all know a PI head swap on a 96-98 GT will result in a compression ratio to aprrox. 10:1. My question is, is this reliable and safe on a 90,ooo motor gt, hardly abused at all? Will this increase in compression hurt the motor over time or help it? Let me know guys. No blower will be added in case you are wondering. Thanks
GoBabyVroommm
1,156
Chicago, For Realss???!!!
Dec 11, 2004
  • Dec 11, 2004
You'll be fine. Sometimes your compression ratio will change because of the head gaskets your use. The faster you do the PI swap the longer your motor will last. The intake that the 96-98 sucks ballz.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 11, 2004
  • Dec 11, 2004
you're putting new parts on your car, it won't make it worse. if you do the swap just brush off the carbon on the pistons. the compression will rise between 10:1 to 10:5.
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Dec 11, 2004
  • Dec 11, 2004
Just make sure you use the correct grade of fuel to avoid detonation. I also have my timing advanced to 15 degrees BTDC, run 93 octane and never ping.
82,000 and going strong. It's a good engine...change your oil & filter regularly.
P
Pitch Black
369
TX
Dec 11, 2004
  • Dec 11, 2004
10.1:1 is perfectly safe.....unless you plan to boost
Stanglover96
46
Knoxville
Dec 11, 2004
  • Dec 11, 2004
What about with nitrous? Would it be better to get a flip chip and get 2 tunes or what? Also I heard about a bump on the heads that if taken out reduces compression by 1 pt. Is that true?
Blev
1,295
So. Cal. V-Town
Dec 11, 2004
  • Dec 11, 2004
I don't know anything about a "bump" but I know if you remove the swirl dams it lowers the compression.
kah9911
102
Downingtown, PA
Dec 11, 2004
  • Dec 11, 2004
Well the swirl dams are kind of like bumps. I would not worry to much about a CR of 10. I think they only take out like .5 also, but your fine at 10. Just run higher octaine and you will make a bit more power.
01TrueBlueCobra
336
somewhere
Dec 12, 2004
  • Dec 12, 2004
The only thing different is that you have to run premium gas. Also the Mach 1 is 10.1 compression too. Also make sure you take your short block assembly to a machine shop to have it rebuilt.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 12, 2004
#10
  • Dec 12, 2004
  • #10
If you're refering to their flow characteristics, yes, the do in fact "suck ballz" but if it's the fact that their all plastic design makes them prone to cracking, up until 2002 model year, PI intakes were all plasic as well. You gotta specify the intake with the aluminum crossover if that's the case.
Which also makes it brutal on gas. I wouldn't knock em off if I were him.
P
Pitch Black
369
TX
Dec 12, 2004
#11
  • Dec 12, 2004
  • #11
Nitrous is safe as well. You have to realize that there are many cars out there running a 10.1 CR. Mach 1's, LS1's, etc., all run 10.1:1 CR stock. There are THOUSANDS of LS1's running nitrous without any problem. You don't need to worry about your CR until you boost the engine.
Screamin' Demon
204
winchester, va
Dec 12, 2004
#12
  • Dec 12, 2004
  • #12
Well I already have my timing advanced through my chip and I run premium right now currently. Cant wait to have these heads and cams.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
V
pushrod 5.0 (MILD/ Torque) turbo build for an old scout II help
  • vz58
  • Apr 21, 2024
  • Other Auto Tech
2K
Other Auto Tech Jan 21, 2026
Flyboy60
F
