Compression ratio help
1973stang
46
Bore X Bore X .7854 X stroke= Cylinder Volume V1
Bore X Bore X .7854 X Deck Height= Deck Clearance Volume V2
Bore X Bore X .7854 X Head Gasket Thickness= Gasket Opening Volume V3
Comustion Chamber Volume in CC's(cubic centimeters) To Convert CC's to Cubic inches, Multiply CC's by .06102 CC's X .06102= V4
(V1+V2+V3+V4)/(V2+V3+V4) = COMPRESSION RATIO
This is some info I found on another forum about compression ratios.
My build is on a 1973 351C with 2V 76.2cc .40 over bore, stock stroke.
I am using these pistons do I subtract 2 cc's from the cylinder head cc for the equation? Also should these pistons work and not hit the valves? Will I be able to run pump gas?
Any estiments on the compression I should be seeing?
The block and heads are stock deck heights
Keith Black/KB Pistons KB177-040 - Keith Black Hypereutectic Pistons - Overview - SummitRacing.com
Piston to valve contact will also depend on the cam grind you're going to use. More so than those pistons. You will have no worries about running pump gas with those heads and dished pistons. Quite the opposite, you're going to have to choose wisely on a cam grind to avoid lowering the dynamic ratio with that combo.
UPDATE
I plugged the info into a compression calculator and came up with roughly 9.8:1
The pistons barely have a dish, its just one valve relief if you take the time to look at the link.
And I was thinking a 268 comp cam or edelbrock performer. (going for mild performance.
