compression ratio??
  • Thread starter Thread starter tretz
  • Start date Start date Apr 20, 2006
T
tretz
62
stockton, ca
Apr 20, 2006
  • Apr 20, 2006
Can someone figure my comp. ratio for me ?
4.030 bore
3.00 stroke
-.028 piston position
frpp gasket set head gasket
58cc chambers
not looking for the exact # but somthing close
If you need more info, ask
J
John Z
581
Morgantown WV
Apr 21, 2006
  • Apr 21, 2006
Compression ratio = Compressed volume/(compressed volume + swept volume)
Compressed volume = head + gasket thickness + "piston position"
head = 58 cc = 3.54 ci
gasket thickness volume = T*pi*(d/2)^2 = 0.04*3.14*(4.03/2)^2 = 0.51 ci
Assumed 0.04" thickness
"piston position volume" = same as above but use 0.028 for T = 0.51ci
swept volume = same as above but use T=3, 38.27
So the compression ratio is about 9.7:1
T
tretz
62
stockton, ca
Apr 22, 2006
  • Apr 22, 2006
thank you, how much do I lose to the valve reliefs ?
D
D.Hearne
11,730
south louisiana
Apr 22, 2006
  • Apr 22, 2006
He's not going to get 9.7 with the piston that far down the hole. Multiply the bore radius times itself (2.105x 2.015) then times pi (3.1416) then times the stroke ( 3.00) then times 16.387 ( to get the swept volume to ccs) Gasket volume is going to be 9.5 ccs. volume of the .028 deck clearance is about half that ( 4.5 ) Volume of the piston top is about 5 ccs for flat tops with 4 valve reliefs. I don't have my calculator handy but I can tell you that the ratio is going to be close to 9 to 1 give or take a few tenths of a point. To get 10 to 1, you need zero deck pistons which will have a pin height ( comp height) of 1.610.
T
tretz
62
stockton, ca
Apr 23, 2006
  • Apr 23, 2006
didn't mean to start any arguements I just was curious, I just wanted to end up between 9 and 9.5 and it looks like i'm close, thanks again for the response
J
John Z
581
Morgantown WV
Apr 24, 2006
  • Apr 24, 2006
My original calc did not include the valve relief. With a 5 cc valve relief the compression drops to 9.1. The valve relief was not mentioned in the first post, so I left it out. I'm suprised with how much it affects compression ratio.
D
D.Hearne
11,730
south louisiana
Apr 25, 2006
  • Apr 25, 2006
It doesn't take a lot of ccs to affect the ratio with small displacement engines. Not many take the time to figure it out, and wind up with less than they thought with 289-302's. The key here is piston choice, not all 302 flat tops have the correct compression height to get the ratio up to 10 to 1. Many have a 1.585 comp height, but you want a 1.610 to get it up there for aluminum heads.
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
4K
Classic Mustang Specific Tech Yesterday at 4:44 PM
horse sence
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
