Compression Results
  • Thread starter Thread starter BurningRubber
  • Start date Start date Dec 4, 2007
BurningRubber
1,865
24
58
Dec 4, 2007
  • Dec 4, 2007
I changed my plugs today and did a compression test while doing so.
I unplugged all the coil packs and injectors, cranked the engine over several revolutions @ WOT per cylinder (all other plugs in place). This is how I was told to do it, is it correct?
Drivers side, #1 is closest to the radiator.
1: 162psi
2: 172psi
3: 170psi
4: 165psi
Passengers side, #1 is closest to the radiator...
1: 150psi
2: 123psi
3: 160psi
4: 120psi
Not too happy with the passengers side...
I guess spraying it is a bad idea.
124k on the engine by the way.
mazen189
424
I.E. southern california
Dec 4, 2007
  • Dec 4, 2007
thats not that bad for 124k, i mean, honestly, after 120k is when i started having lil problems from here and there.
D
darkside03gt
851
Sacramento CA
Dec 4, 2007
  • Dec 4, 2007
I would check cylinders 2 and 4 again just to make sure those numbers are accurate. 123 and 120 is a little to low.
BurningRubber
1,865
24
58
Dec 4, 2007
  • Dec 4, 2007
mazen - Yeah I figure thats probaly where a little bit of my oil is dissapearing to, but its been beat on by me and the previous owner.
darkside - I re checked the first cylinder that came up low, it repeated the same results so im very confident those are correct. I was bummed out about those 2 cylinders.
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
