  • 1994 - 1995 Specific Tech
Compression test making me worry.
  • Thread starter Thread starter 1105
  • Start date Start date Dec 17, 2004
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Dec 17, 2004
  • Dec 17, 2004
I did a test tonight and all my numbers were really low (below 60). Found out from my dad that the gauge might have a small leak in it, but almost all of my numbers were consistant except for two... 1,2,3 all read 60psi, and 4 read 10psi but the plugs all looked OK. 6,7,8 all read 50psi and the plugs looked OK, but number 5 didnt give me a reading at all, even after doing it 3 diff times, and the plug was pitch black.
Anyone have any ideas why number 5 didnt even give me the slightest reading? I know the reason why number 4 is low, but I'm stumped by number 5 and the black plug where the others were a light grey.
I'm going to try tomorrow to do another compression check at work using his gauge to get a 2nd reading, but that one plug is making me worry. Either that cylinder isnt firing, or the injector is stuck open, or something else. Got any ideas?
Stock block and internals, almost 130k miles.
WhiteDevil
2,717
San Diego
Dec 17, 2004
  • Dec 17, 2004
When did it start running like crap?
1105
May 3, 2003
3,841
Daytona Bch, FL
Dec 17, 2004
  • Dec 17, 2004
Hitting the gas at any RPM in 2nd gear and the tires will still get blown away Running better than it ever has right now.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Dec 17, 2004
  • Dec 17, 2004
I think it's the gauge itself. With #'s that low would mean the rings are so worn so bad you would burn a quart of oil a day if not more. Does it smoke at all?
1105
May 3, 2003
3,841
Daytona Bch, FL
Dec 17, 2004
  • Dec 17, 2004
no smoke at all, doesnt burn oil. I think its the gauge, but even so, number 5 would have to have been real low for it to have leaked out by time I got to it, and that was the only plug that was completly black... I had my g/f watch it one time for #7, she said it hit 100, which is still low, but when I got there it was at 50 and just barely creaping down.
I know that the gauge is leaking, but from 60 on down, the needle barely moves, maybe 1 psi every minute so I should have got at least somewhat of a reading for #5.
WhiteDevil
2,717
San Diego
Dec 17, 2004
  • Dec 17, 2004
Well i would say as long its running good dont worry about it. But i know how things like this can bug you.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Dec 17, 2004
  • Dec 17, 2004
Go to autozone and but there cheap testor it $25 and change and retest it. The fact that the gauge can't hold pressure at any point I would just disregard those #'s completly.
1105
May 3, 2003
3,841
Daytona Bch, FL
Dec 17, 2004
  • Dec 17, 2004
But then why is only one plug black? I think I'm just going to test that one tomorrow at work and see what I get.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Dec 17, 2004
  • Dec 17, 2004
When you say black black how? oil,fuel,ie. My # 8 cylinder has a bad injector it sparys the fuel right at the plug soaking it and turning it black. It may be just a bad injector on that clylinder.
OinkAodeOink
3,026
Daytona bch, Florida
Dec 18, 2004
#10
  • Dec 18, 2004
  • #10
hey zach, if you really need to, i have a new compression gauge i can borrow or come over and use..
You know... Your valves could be leaking the compression out.. What you need to do is get someone to look real close at the gauge while you give it like 5 rotations or so, over.. Let the gauge settle and watch its peak. If it drops quickly, this could be a valve/spring/seal problem..
I once had a rocker too tight, and lost almost all compression on that cylinder, so you might wana check the rockers, if you come back with wacky readings.
As far as the plugs go.. If its a dry black, thats most likely a rich condition.. If its a wet greesy black, thats most likely an oil burn condition, either from worn valve guides/seals, or worn rings (oil ring usually)
BTW, im guessing you were holding the throttle wide open? and letting the engine rotate over for atleast 3-4 seconds?
Lemme know if you need to use the gauge, no problem man..
Slow5.0
2,554
Portland, OR
Dec 18, 2004
#11
  • Dec 18, 2004
  • #11
Zach 31st this month in morning I will be in Florida and I will stop by you like I told you, I can help you out with compression test OK
BTW tell Oink that I wanna see him and his Stang and if you have some other members here around your neighbors
1105
May 3, 2003
3,841
Daytona Bch, FL
Dec 18, 2004
#12
  • Dec 18, 2004
  • #12
Earnie, me and Mike are about the only SN95 members around this area that I know of. What day do you want to meet? I'm probably going to be busy on the 4th. But everyother day after that I should be free after work.
The plug was a dirty black, not a shiny clean looking black.
Mike, maybe my valves are adjusted a little to tight because I did a compression check on my car when I had the stock E7 heads on and it was holding pressure at 120-135. I might go ahead and take the valve covers off today when I get home from work and readjust one and see if I get a higher number.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Dec 18, 2004
#13
  • Dec 18, 2004
  • #13
With an honest 60 psi of compression, I don't think it would even start. Time for a different gauge .
Dave
Slow5.0
2,554
Portland, OR
Dec 18, 2004
#14
  • Dec 18, 2004
  • #14
I said December 31st, not 4th , I will stop by and see whats going on
I will let you know where and what time
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Dec 18, 2004
#15
  • Dec 18, 2004
  • #15
Ernie are you driving your car there? Les have a little meet at OSW if its still open.
Slow5.0
2,554
Portland, OR
Dec 18, 2004
#16
  • Dec 18, 2004
  • #16
No man i driving my buddys '96 Cadillac Seville SLS, cheapper on gas ,plus I have no good rear tires (Nitto DRs are bold) , and right now my stang is on V6 rims and tires you know for snow
BTW me and my teo buddys going in Jacksonville FL for New Years eve ,we Bosnians have big party for New Years eve
Next summer I will come with my Stang down there
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
2K
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
