Compression test making me worry.
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
I did a test tonight and all my numbers were really low (below 60). Found out from my dad that the gauge might have a small leak in it, but almost all of my numbers were consistant except for two... 1,2,3 all read 60psi, and 4 read 10psi but the plugs all looked OK. 6,7,8 all read 50psi and the plugs looked OK, but number 5 didnt give me a reading at all, even after doing it 3 diff times, and the plug was pitch black.
Anyone have any ideas why number 5 didnt even give me the slightest reading? I know the reason why number 4 is low, but I'm stumped by number 5 and the black plug where the others were a light grey.
I'm going to try tomorrow to do another compression check at work using his gauge to get a 2nd reading, but that one plug is making me worry. Either that cylinder isnt firing, or the injector is stuck open, or something else. Got any ideas?
Stock block and internals, almost 130k miles.
no smoke at all, doesnt burn oil. I think its the gauge, but even so, number 5 would have to have been real low for it to have leaked out by time I got to it, and that was the only plug that was completly black... I had my g/f watch it one time for #7, she said it hit 100, which is still low, but when I got there it was at 50 and just barely creaping down.
I know that the gauge is leaking, but from 60 on down, the needle barely moves, maybe 1 psi every minute so I should have got at least somewhat of a reading for #5.
hey zach, if you really need to, i have a new compression gauge i can borrow or come over and use..
You know... Your valves could be leaking the compression out.. What you need to do is get someone to look real close at the gauge while you give it like 5 rotations or so, over.. Let the gauge settle and watch its peak. If it drops quickly, this could be a valve/spring/seal problem..
I once had a rocker too tight, and lost almost all compression on that cylinder, so you might wana check the rockers, if you come back with wacky readings.
As far as the plugs go.. If its a dry black, thats most likely a rich condition.. If its a wet greesy black, thats most likely an oil burn condition, either from worn valve guides/seals, or worn rings (oil ring usually)
BTW, im guessing you were holding the throttle wide open? and letting the engine rotate over for atleast 3-4 seconds?
Lemme know if you need to use the gauge, no problem man..
Zach 31st this month in morning I will be in Florida and I will stop by you like I told you, I can help you out with compression test OK
BTW tell Oink that I wanna see him and his Stang and if you have some other members here around your neighbors
Earnie, me and Mike are about the only SN95 members around this area that I know of. What day do you want to meet? I'm probably going to be busy on the 4th. But everyother day after that I should be free after work.
The plug was a dirty black, not a shiny clean looking black.
Mike, maybe my valves are adjusted a little to tight because I did a compression check on my car when I had the stock E7 heads on and it was holding pressure at 120-135. I might go ahead and take the valve covers off today when I get home from work and readjust one and see if I get a higher number.
I said December 31st, not 4th , I will stop by and see whats going on
I will let you know where and what time :nice:
BlueOvalStangGT said:
Ernie are you driving your car there? Les have a little meet at OSW if its still open.
No man i driving my buddys '96 Cadillac Seville SLS, cheapper on gas ,plus I have no good rear tires (Nitto DRs are bold) , and right now my stang is on V6 rims and tires you know for snow
BTW me and my teo buddys going in Jacksonville FL for New Years eve ,we Bosnians have big party for New Years eve :cheers:
Next summer I will come with my Stang down there :nice:
