Compression Test..
Bluffing024
Somewhere
Hey everyone.
I am thinking of buying a 99 Cobra and I want to have a compression test done on it to make sure everything is up to par...(link to thread about the cobra http://forums.stangnet.com/showthread.php?p=6824288#post6824288 ) What is a fair price to get one done? I just called Pep Boys and they said anywhere from $99 to $130 (guy sounded like an idiot though). Anything else I could look for? Thanks for any help..:SNSign:
Is there a write up on how to do one and what tools are needed? I am looking at that 99 Cobra and an 98 T/A LS1 (Evil, I know.) So knowing how to do it could help me out so I am not paying to get them both done. The T/A is at a dealership so they may do it for me? Thanks for any further info.
if you can rent the gauge, it's simple. take out the spark plug, gently thread in the gauge, crank the engine w/ the coils disconected so it doesnt start then go look at where the needle went highest cuz it'll move a limit needle there. If memory serves me right thats how you do it
Disable igntion, take all plugs out, insert tester and hold throttle wide open and crank motor several(5-7) compression strokes. If you have a helper be sure to look at the 1st reading you get, when you start the test on each cylinder and the highest reading on each cylinder.
If they are all cylinders are with in 10% of each other you should be good. If one or more cylinder are allot lower than the others do a wet test.. Put some(couple squirts) 30wt oil in the cylinder and repeat test. Higher numbers mean, rings or cylinder is bad, no change in number tells you bad valve...
