Let's see if gearbanger can understand this. Let's just assume for a minute that we have a stock motor for comparison’s sake. According to my personal measurements on a '02 motor I just experimented with, here are my findings:
3.552" bore
3.543" stroke
8.934" deck height
1.219" compression height
-15.78cc piston volume
42.44cc combustion chamber total volume (including valve dish to compensate for the lost volume of the emissions mask or swirl dam)
.0153" piston to deck clearance (deck clearance)
.030" stock head gasket compressed (installed) thickness
3.625" head gasket bore (fire ring bore)
I documented much more info, but the rest is not relative to use for compression ratio calculations.
According to the above findings, I calculate the SCR of this motor to be 9.746:1
Gearbanger 101 said:
Since head gasket thickness has already been addressed above, why would you think his cylinder bore would affect things to any great extent? The increase in volume from stock to say a standard overbore of .020 is something like less than a single CC where these small bore engines are concerned, which is hardly a significant amount.
I said "head gasket bore" not cylinder bore. Two very different things. I realize now that you don't know this, but the head gasket bore (fire ring bore) is always larger than that of the cylinder bore. Combined with the compressed thickness of the head gasket, this equates to head gasket volume which will obviously affect SCR.
Now that we've cleared that up and back to the SCR of this stock motor that I experimented with, let's assume just for a minute that we will keep my shortblock in question otherwise un-modified. Now let's assume we will install a set of Stage III Patriot heads and use a gasket with a stock .030" x 3.625" head gasket.
Most of the Stage III 2V modular heads that I have worked with have right around a 46cc combustion chamber. The set I have in the shop right now measure exactly 46.20cc.
That change alone in combustion chamber volume takes the stock compression I measured of 9.746:1 down to 9.273:1....or basically half a point. On a 281" motor, like Stan mentioned, is definitely significant and will change the way the motor is tuned and the amount of boost it will take.
Now with the last information that bdp55 posted, this of course will change the SCR as compared to a stock shortblock. Like Stan eluded to, without knowing the specifics of your final build yet, it is impossible to finitely calculate your SCR. But, will just make a educated guess.
bdp55, assuming going .020” over, having the block square decked, using the Patriot Stage III heads with a 46.2cc CC,
assuming the piston is .010” in the hole (fairly common on your type of build using a Cobra 4340 3.543" crank and 5.933” rods), and assuming you use a .030 gasket (Cometic or stock), and the 19cc pistons, I “estimate” that you will be around 9.09:1 SCR….. this should be relatively close, BUT, just remember this just an
estimate since we don’t know your final build specs.
