  • 1994 - 1995 Specific Tech
Compression
  • Thread starter Thread starter pirotec354
  • Start date Start date Oct 25, 2008
pirotec354
127
Grand Rapids, Michigan
Oct 25, 2008
  • Oct 25, 2008
Anyone know if theres a way to measure a compression ratio without having to tear the motor down or is there now way. Because i want to run about 18 psi but i wanna be safe and see where im at with compression. Im running ten right now, but i want to be safe. Thanks in advance for any help
earleys94gt
1,223
Ashley, Ohio
Oct 26, 2008
  • Oct 26, 2008
This might help...
RSR Static Compression Ratio Calculator
or this...Compression Ratio Formula
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Oct 27, 2008
  • Oct 27, 2008
if you dont have enough engine/head info, you can do a compression test, divide your results by 14.7 and that is a rough idea of your CR.
Dino Dino Bambino
1,672
89
79
Cyprus
Oct 27, 2008
  • Oct 27, 2008
That won't work and the result will be wrong. Cranking compression gives an indication of the DYNAMIC compression ratio which is influenced by the valve opening/closing events, particularly the timing of intake valve closure.
To calculate the static compression ratio, you need to measure the cc of the following:
1. Combustion chambers
2. Piston dish or valve reliefs
3. Head gasket bore (you can calculate the bore volume if you know the bore diameter and compressed thickness)
4. Deck clearance volume (you can calculate that from the cylinder bore diameter and deck clearance)
I'll leave out the crevice volume (space between the cylinder bore and the piston from the crown to the upper ring) because that's negligible.
pirotec354
127
Nov 8, 2008
  • Nov 8, 2008
Alright well thanx guys i guess ill just take my heads off while the car is in storage for the winter and go from there.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Nov 9, 2008
  • Nov 9, 2008
I guess I should have put "rough idea" and "don't have enough engine/head info" in bold....My bad
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
