Cobra computer
24 lb injectors
Stock calibrated MAF sensor
Those three things in combination are correct.
Pull codes and see what the computer thinks is wrong. My guess is that you've got a vac leak someplace that's leaning out your mixture. You may also want to check fuel pressure and ensure that it's correct. Is the meter you're using out of a Cobra or is it a GT/LX meter? From what I understand, there are differences in calibration between the two.
