  • 1994 - 1995 Specific Tech
Computer retrofit
  • Thread starter Thread starter SpitfireMk24
  • Start date Start date Oct 8, 2004
SpitfireMk24
140
Livermore, CA
Oct 8, 2004
  • Oct 8, 2004
From reading mm+ff, I guess 94-95s have a computer that doesnt respond to mods all that well, in other words, if you buy a cam, your gonna have a sucky idle. . .
Has anyone done the computer retrofit to fix this problem? what mods are you restricted to if you dont replace your comp?
HoofnIt
1,175
North Carolina
Oct 8, 2004
  • Oct 8, 2004
Pro M makes a PIH (Plug In Harness) which allows you to swap in an A9L Fox computer. These older computers appear more 'mod' friendly and don't REQUIRE a tune after nonextreme cam and head changes. Most people say that this is only a band-aid and is NOT a custom solution. They say the 94/95 computer is actually better, it just needs 'tweeked'. If your cam is even somewhat mild, you will run into idle/drivability issues, I did. You have more options besides the PIH, you can get a chip, a tweecer, PMS, or EEC tuner. I chose the PIH route. I'm doing the swap next month.
95strokerPSU
986
Sacramento from Philly
Oct 8, 2004
  • Oct 8, 2004
I did the PIH switch, I recommend it.
HoofnIt
1,175
North Carolina
Oct 8, 2004
  • Oct 8, 2004
Oh yea, I almost forgot. If you do the PIH swap you will need an aftermarket ignition.
95strokerPSU-how much did you gain after the swap? Which crower cam are you running?
1hot5.0
1,615
Surprise, Arizona
Oct 8, 2004
  • Oct 8, 2004
How did your car react after the swap?
S/CBlack95GT
2,018
Tampa Palms, FL
Oct 8, 2004
  • Oct 8, 2004
Some cams out there will work fine with the 94-95 computer. Usually these cars don't like a lobe separation under 112 degrees or a duration over 226. I have stuck with the stock cam just for the reason of having something to brag about. The Anderson B-cam would really wake a car like mine up with almost no driveability problems.
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
Engine An engine building combo with stock Speed Density (SD) system
  • Mcmahst
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 15, 2025
Mcmahst
O
Computer swap
  • Oakman
  • Jun 22, 2024
  • The Welcome Wagon
The Welcome Wagon Jun 22, 2024
Oakman
O
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
