Control arm bolts
  • Thread starter Thread starter RB92GT
  • Start date Start date Nov 10, 2007
R
RB92GT
42
Jacksonville, FL
Nov 10, 2007
  • Nov 10, 2007
Just bought MM adj LCA's and Ford HD upper control arms. Local dealership wants $17.50 per bolt and $2.30 per nut. I need 8 of each! Any suggestions on where to buy the bolts/nuts? Anyone have a local dealer that gave them a better price on the bolts. I would be willing to contact that dealer and pay shipping. Thanks. I found out that UPR has them, but I don't hear great things about that company.
R
RB92GT
42
Jacksonville, FL
Nov 10, 2007
  • Nov 10, 2007
Oh ya, if you couldn't tell by my name, I have a 1992 GT.
4G-KDMP
935
CA
Nov 10, 2007
  • Nov 10, 2007
same bolts and nuts
http://www.breezeautomotive.com/details.php?prod_id=170&cat_id=34
FSTNG
37
Tampa Bay, FL
Nov 10, 2007
  • Nov 10, 2007
Why not go to a hardware store or fastener supply house?
4G-KDMP
935
CA
Nov 10, 2007
  • Nov 10, 2007
you would need to buy a class 10.9 galvanized bolt which i think would really be hard to find at hardware store.
the bolts sold on that site have anti-corrosion finish the same as the oem.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Nov 10, 2007
  • Nov 10, 2007
10.9 is hard to find.
Grade 8 would be easier, and is more rugged than 10.9....however being a metric pitch i doublt you'll find it any other way than 10.9
10.9 and grade 8 are close, but grade 8's standards are slightly better
F
frcefedlx
184
  • Nov 10, 2007
I could be wrong but late model restoration sells the bolts in a kit as well.
jammer84_03
468
  • Nov 10, 2007
just did the same thing. edelbrock has them on summit for $15. you would have to get two sets to do both uppers and lowers. plus the greatest thing about it is you get standard sizes instead of that metric garbage 18mm stuff. mm recommends the ford original stuff, but i have no issues with these
http://store.summitracing.com/partd...rt=EDL-5216&N=700+4294814570+115&autoview=sku
rd
3,316
63
109
Ocean Springs MS
Nov 10, 2007
  • Nov 10, 2007
Dumb question, but why can't you just use the old ones?
I have reused all of mine on, the 79, and the 82, any through many rear end and control arm changes, except the rear lowers on the 82, because I needed longer ones to hold the extra thickness of the traction bars. I got plain old grade 8 bolts at Lowes or a hardware store, if I remember correctly.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 12, 2007
#10
  • Nov 12, 2007
  • #10
You might check with Greens as they will have OEM Ford Parts but they should be cheaper than the Dealer.
blown1989saleen
1,397
oxford,pa
Mar 7, 2008
#11
  • Mar 7, 2008
  • #11
go to a good hardware store and get Grade 8 hardware in the appropriate size
D
Deleted member 87397
Mar 7, 2008
#12
  • Mar 7, 2008
  • #12
UPR grade 8 sets for about 20 bucks.
Maryland Stang
1,656
30
39
Greenville, NC
Mar 7, 2008
#13
  • Mar 7, 2008
  • #13
I got grade 8 from the hardware store and installed with anti-seize.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 7, 2008
#14
  • Mar 7, 2008
  • #14
I always thought those Bolts had a Shoulder on them which you would most likely not find at the Harware Store.
onefstsnake
792
Northern VA
Mar 7, 2008
#15
  • Mar 7, 2008
  • #15
When I put new Control arms on mine I went to www.McMaster.com and ordered all my hardware.
All 10.9 Zinc Coated stuff with Nyloc nuts.
Not cheap but it will never rust.
Edit. Here is the shopping list I had from their site. And for some reason BreezeAuto says its a 16mm bolt... I used 12mm and they fit tight...
1 95327A704 Metric Znc Yellow Pltd Stl Hex Head Cap Screw, Class 10.9, M12 Size, 90mm Length, 1.75mm Pitch 1
Pack of 5 $10.22
2 95327A708 Metric Znc Yellow Pltd Stl Hex Head Cap Screw, Class 10.9, M12 Size, 100mm Length, 1.75mm Pitch 1
Pack of 5 $10.87
3 94645A230 Class 10 Zinc-plated Stl Nylon-insert Locknut, M12 Screw Sz,1.75mm Pitch, 19mm Width, 12mm Heig 1
Pack of 10 $7.05
Supercharged89
Florissant,Mo.
Mar 9, 2008
#16
  • Mar 9, 2008
  • #16
Shakerhood is right. Hardware stores don't have bolts with shoulders. Just get the correct ones.
T
trueblue01
141
West Palm Beach, Florida
Mar 10, 2008
#17
  • Mar 10, 2008
  • #17
I just installed the one from UPR. They don't have the shoulder but the whole bolt is the same diameter as the shoulder part on the stock bolts. They came with nylon locknuts and are standard not metric. Plus they are under $20 for upper and lowers.
Maryland Stang
1,656
30
39
Greenville, NC
Mar 10, 2008
#18
  • Mar 10, 2008
  • #18
The bolts that I put in (1/2" I think, it's been a while) are tight in both the arm and the mount points on the car. It's not something I'm concerned about.
Nova
128
#19
  • Mar 10, 2008
  • #19
http://www.uprproducts.com/shopping/shopexd.asp?id=1091
C
1965 Mustang Lower Control Arm Question.
  • chopper1876
  • Nov 9, 2024
1965 - 1973 Classic Mustangs -General/Talk- Dec 7, 2024
GOvert
G
  • Locked
SOLD Maximum Motorsports MMTR-2 Bumpsteer Kit - 1979 - 1993 Mustang
  • AeroCoupe
  • Apr 18, 2025
Fox Body Mustangs For Sale (1979-93) Aug 5, 2026
AeroCoupe
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
7K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
Suspension Foxbody ride height change after installing new control arms
  • Mhalc1
  • Jan 3, 2024
10K
Fox 5.0 Mustang Tech May 10, 2024
Mhalc1
P
Transmission to radiator connection
  • P0nyRider
  • Aug 5, 2024
1996 - 2004 SN95 Mustang -General/Talk- Sep 23, 2024
4gwenddolau9
