I have a set of Pro3i,s upper and lower control arms and when I bought them it was just that, no hardware.I am ssuming that the old stock hardware is to be recycled. If this is not the case how do I find out what size bolts and such I will need for the install. Also looking through my chiltons it saysthat the hardware for the sway bar should be removed and all new stuff put on. Is there a place that sells this hardware as a kit or do I need to remove it and go from there. I really like to have everything before I start any project and so far this information eludes me. I have allready done a search on this with no luck. Thanks Stangnet.
You forgot to add the price of the hardened washers, as the hex heads do not have the flare that the stock bolts have (atleast I coulndt find them). All of my control arm bolts were the same length, and all four lower control arm bolts were badly corroded, and therefore seized on the inner sleeve in the bushing. It took a little convincing to remove the ones that didnt break. I just took an electric impact to the bolt and rev'ed the snott out of it while tapping the opposite side with a punch.
