i already have a 5 lug car using the ranger axle & drum trick. now i want to change the rear to disc brakes. i was told 94 mustang brakets, caliper, rotors & pads.......what else and is it that easy??????
You can use 1994-2004 rear calipers, brackets, rotors, anti-moans, dust shields, 1994-1995 rear soft lines, 2 adapter fittings for the head lines to the soft lines and 1994-1998 axles.
That's just in the rear
you will also need to upgrade to a Sn95 MC, a 93 cobra or sn95 booster, gut the stock prop valve and install an adjustable prop valve
