Converter Suggestions
DaOnE51T
250
Queens, NYC
I need some help picking a nitrous converter. What stall should I get? Which converter company should I go with.
Here is my combo:
Purpose: Street/Mostly Strip
Type of Transmission: C-4
Transbrake: Yes
Engine Size: 306
HP: Estimated 475
Torque: Estimated 400LBS
Compression: Around 10:1
Stroke: 3.00
Bore: 4.03
Flywheel Size: 164th
Flywheel weight: 50 ounce
Type of Heads: Windsor Sr.
Carb: Holley 750 DP with proform main body(900cfm)
Cam lift intake: .630
Cam lift exhaust: .640
Duration @ .050 intake: 250
Duration @ .050 exhaust: 260
Cam Centerline: 106
Header Size: 1 3/4
Rear-end ratio: 4.56
Tire Size: 28x10x15
Intake valve size: 2.02
Exhaust valve size: 1.60
Power Adder: Nitrous
Vehicle Weight: Around 3,000LBS
Shift Point: N/A
Trap RPM's: N/A
Suspension: Ladder Bars
E.T: N/A
MPH: N/A
60 Foot time: N/A
Current Converter: 10" Dacco Igniter S/S with advertised stall speed
3,400-3,800
THANKS, PEACE 1
TCT/Dynamic is one of the top companies out there unless you want to go Neil Chance ($2000).
I know a lot of guys are very happy with www.edgeracingconverters.com, you may also want to look into PTC.
Work with what ever company you choose to find out the correct specs, every combo is different. Vehicle Weight is important as well...
