So regarding convertible structure what is it that keeps the foxes from buckling in the center is there some huge piece of steel inside the rockers or something? Surely the sheet metal floor alone wouldn't be enough.
I wasn't aware there was a strut tower brace.
I stand corrected. Been a while."There is an aluminum piece that runs along the rocker front to back, it is riveted.'
If the piece you reference is the one that runs on the underside of the rocker panels between the front and rear wheels, that is a steel piece, not aluminum.
Over my Christmas vacation I installed MM full length subframe connectors. The factory convertible braces have to be modified on the convertibles (my car is). The front ones get removed, part of it cut off and then it's welded to the frame connector and that steel brace on the underside of the rocker. The rear braces over the torque boxes get the rivets removed where they go though the frame rail, you cut a slit in the brace, then weld it to the frame rail.
It was a big job for sure, but well worth the effort, especially on a convertible. I'm looking forward to driving the car when I get a few more things done to see how it feels with the subframe connectors instslled.
