- Aug 9, 2004
- 31
- 0
- 0
Killercanary said:Spare, jack, 25lb passenger vert weight, 10lb dog bone weight, aluminum driveshaft, alum. heads, alum pulleys, remove the strut tower brace, pull the pass seat, pull the rear seats, pull the rear trunk carpet and plastic, remove the floor mats, run with 1/4 tank or less of fuel, lightweight drag wheels, etc... how crazy do you want to get? What I listed here will drop 200lbs.
greenlantern said:That is a little crazy. What is a 10lb dog bone weight? And how much weight would you save with the rear seat delete?
if im not mistaken that would be that big a$$ weigt behind the passanger fender.maybe killer can varify that.greenlantern said:That is a little crazy. What is a 10lb dog bone weight? ?
95opal said:so whats the big weight behind the front passanger side?
CManT1914 said:Well these guys pretty much summed it up, lightweight suspension will also help, i.e. tubular k-member etc.. Also, the sound deadening material under the rear carpet is supposed to weigh 80 lbs. or better!! That's a good chunk of weight if you don't mind living with an obnoxiously loud car.![]()
I have prety much everything mentioned above done. ALso front and rear bumpers and all associated hardware stripped also. All factory ties removed and chromoly ties welded into floor boards.I do have certified chromoly 8pt cage and when put on chassis scales it weighted in at 2980 with 1/2 tank of gas..I replaced factory carpet with 50 resto carpet and all padding removed. You can see in my garage..blackstanger95 said:How do you lose weight from this heavy pigs? Im trying to lose at least 200 lbs. Is it possible?
