jasonh_86 said:So it more or less "Bleeds" itself if you leave the cap off, hold the revs at 1500 and have the heat on full blast?.. And it's done "bleeding" when the heat is blowing strongly at idle?
So, just follow that article.. and then do the heat/1500rpm thing w/the cap off when i'm done?.. Are there any extra hoses to take off?.. and can somebody give me a write-up or something for putting the new t-stat on?
Thanks Killy! I'll try to pick up a bottle of that stuff before I get started on itKilgore Trout said:I would def recommend using the Water Wetter![]()
svttech76 said:well more or less yeah it bleeds itself. just make sure you do it unless you like doing headgaskets.
I'll DEFINATELY remember it now!!.. not like I was gonna forget, but that's quite a big reminder!!
self-ownage?svttech76 said:sounds good. but now you will ahve to bleed again because you opened the system to install the T-stat
Nothing is learned if it comes too easily.svttech76 said:well a little. but it's ok.
. J/K, hes probably on a test drive
I didn't know I needed to bleed it again!
.. wanted to get nice and toasty and it never once blew anything cold out
jasonh_86 said:I didn't know I needed to bleed it again!
But.. before I left the house, I turned my heater on full blast at idle to unfog my windows and warm up the car a bit while I was putting about 5 CD's in the cd player and taking my coat off (and checking the guages).. wanted to get nice and toasty and it never once blew anything cold out
From the time I bled the system til the time I started my car up after the T-stat install was about 2 hours. It sat in the garage with the hood popped.
Flush it down the toilet. That's what deftsound and I did with mine.Stang|ess said:stupid question, but what do you do with the coolant? just let it go down a storm drain to meet some fishes, and hopefully the neighbors cats?
