hotmustang331 said:Youl love the RP in the tranny. And update teh sig. (re timing)
Stang|ess said:So Jason, what did you do with the coolant?
And no thanks to me? I made you feel like less of a n00b.
d90212 said:i thought i recognize that ugly avatar from forums hawaii.
I believe the heater engages the heater core, which in turn heats the engine faster, making the whole process you just mentioned go a lot quickerd90212 said:just curious, why do you need the heater on? theres no heater valve like some rangers and explorers. i guess theres no hurt in having the heater on.
just fill up the reservoir with the cap open, run the car until the thermostat opens, sohc - upper radiator hose will get hot
dohc-lower radiator hose will get hot. if your unsure, your high speed fan should come on a few minutes later. if you leave your a/c on- the low speed fan will come on as soon as your a/c compressor engages, so leave the a/c off.
leave it running for a few minutes, top off fluid. cap reservoir. recheck reservoir when cool
. J/K haha.
nooo.. I take it to Auto Zone or somewhere that accepts oil.
So I made sure it was completely disposed of and washed away before I let any animal near the area ADRENLN said:i see. thanks guys. so it would just be easier if i left the heater core in?
or is that the main part that traps the air pockets so im better off with out it?
either way i can still bleed the system it will just be more trouble is what you guys are saying right?
thanks again.
. And you will have almost 0 issues with air pockets in your cooling system
. Who needs that crap when the car isnt a DD
