Well I want to change my coolant hoses, because they are starting to get brittle at the connections.
I know the two large ones are called radiator hoses. but what are the two smaller ones that run from the water pump to the passenger side of the firewall called? Do all of these come in one large package or need to be purchased individually? What am i looking at price wise here?
Once this is down just slide it off and like Buff said you probly will have to use a straight hose which probly will mold to you car over time anyways.
Now it can get expensive also...I had to disconnect my A/C lines which cost me 75.00 in R12 to recharge the system since I didn't have a chatch can. It also cost me 50.00 to vaccum down the system to check for leaks. NO I want use R 134a unless I have to. It doesn't always work worth a flip on older systems. I simply put that he/she would be wise to avoid damaging the core since its a big hassel to mess with and I would also call is costly to replace due to the amount of time needed to do the work.
